Knock Sensors for 03-04 Cobra and MS3Pro PnP - Page 2
Results 16 to 21 of 21
    Member Array 01yellerCobra's Avatar
    Nov 2006
    San Diego
    88
    Here's what I ended up picking up. I'm only running one sensor for now for various reasons. Once my ECU gets back to me I can try it out.
    Knock Sensor-
    Replacement RF31120001 | CarParts.com
    Stud-
    S8X10X46BLK - Step Stud Black [S8X10X46BLK] - $3.99 : Bel-Metric, Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
    Nut-
    Search Results : Bel-Metric, Metric Hardware, Metric Fasteners, Metric Bolts, Metric Nuts & Time-Sert Thread Repair
    Nov 2006
    San Diego
    88
    Something was bouncing around in my head the last couple days. So I went and looked at the 2V engine I have in the garage and there's no provision for the knock sensors. I looked at the base GT tune and the knock sensors were disabled. I reached out to Matt and he said they don't have a baseline setting for the knock sensors. Even for the Mach 1 which I know has them. So I guess it's time to experiment.
    Bob, you might want to validate that sensor as being usable on a Mustang. When I checked the site it indicated the sensor was not compatible with a Mach I Mustang. That may just have been a connector difference or it may be an indication the sensor was tuned to s specific frequency range for its target vehicle engine. If it is a connector issue no big deal. If it is a tuning for a specific knock frequency signature that gets us back into the tall grass and specific bore sizes and combustion chamber geometry.
    I do like the price though...
    Nov 2006
    San Diego
    88
    That knock sensor is for a 2005-2010 Mustang. The calculators I found seem to only worry about bore size. Which is the same across the 4.6 board. I imagine it's the plug that makes them unable to work with the Mach 1. I changed those to weatherpack connectors anyway.
    Definitely the right price and with only a connector issue it is a no brainier. Great find, Bob.
    Nov 2006
    San Diego
    88
    Ed, I should probably add that price is for two sensors. I'm only running one currently because I was having issues trying to get the second wire installed on the ECU plug and I destroyed one sensor while doing some experimenting.
