Results 1 to 4 of 4
Thread: Help purchasing a 2001 cobra
03-10-2020, 01:14 PM #1
- Join Date
- Mar 2020
- Posts
- 2
Thank you for letting me join ! I'm thinking about buying a 2001 Mustang Cobra with 90.000 miles on it. The motor 4.6 was rebuilt and it runs real good has a 5 speed which seems to be good. After it warms up it has a knocking sound sounds like it is coming from the heads thinking I will have to redo the heads which scares me they didn't do them at time of rebuild, the interior is a 3 from 1 to 10 rating the body is a 5 overall the car rates about a 4 to 5. I can buy it for $6000.00 DON'T KNOW WHAT TO DO CONFUSED !
Sponsored Links Remove Advertisements
06-02-2020, 06:07 PM #2
- Join Date
- Jun 2020
- Posts
- 4
See if you can find a MARKVIII in your area for cheap that has a good motor, you could pick it up cheap, pull the motor and swap it out!
06-04-2020, 05:46 PM #3
Sounds like the car is a big pile of poop and you will flush a lot of money down the toilet if you buy it. I would find another Cobra that is in better condition because if you
can't do the maintenance, paint/body and repair work yourself then you will spend thousands in order to make the car right.
06-05-2020, 07:45 AM #4
