what are these ports on my intake? 4.6 dohc
Results 1 to 8 of 8
    Default what are these ports on my intake? 4.6 dohc
    2000-02 continental intake manifold. I assume one is for the EVAP hose - what's the other? also, can i run the hose for my GM style MAP sensor (aftermarket efi system) to one? The swap is in a 1969 mustang and I'm running a return style fuel system with a spectre efi tank - so wasn't going to run a EVAP system anyhow.
    Any help would be appreciated. Thanks!
    What ECU will you be using?
    An older Accel Gen 7 DFI system
  6. #4
    That is a very old system design. You would be better served with a more current implementation like one of the MS3Pro Plug-N-Play systems. That said, lets assume you continue on with your current Accel DFI system. You should connect all ECU signal I/O to its corresponding device or sensor on the engine. Sensors that have no I/O provisions on the ECU should be removed from the engine and plugged. After that start tuning.
  7. #5
    I already have the system - bought it years ago before life got in the way and stalled this project. It's a pretty basic engine build - just a stockish rebuild so I'm not sure i'll get the benefit per dollar spent upgrading to a newer system.
    The DFI system does not have a provision for a EVAP system purge valve and what not. All that aside, all I'm trying to figure out is what these ports are and whether I can connect the MAP sensor to one and possibly the fuel pressure regulator to the other. I don't want to rely on my assumption that one is for the EVAP and the other is for ??(possibly auto transmission?)
  8. #6
    They look like vacuum ports.
    Take the manifold off and check them out. Then either plug them or connect the sensors you see fit to each one.
  9. #7
    Senior Member Array
    Dec 2005
    Marion, Oh
    108
    What fuel rails are you using, i'm upgrading my 93 lincoln intake to a 96 cobra intake and i need different fuel rails
  10. #8
    Resto,
    Check out your other post. I left some suggestions for you over there.
  11. Remove Advertisements
