For Sale 1999 Turbo SVT Cobra forsale or Trade
Results 1 to 2 of 2
    Junior Member Array
    Jan 2007
    Connecticut
    15
    Default 1999 Turbo SVT Cobra forsale or Trade
    1999 SVT Ford Mustang Turbo cobra
    113k on body 4k since rebuild of car
    This car has a salvage CT title . Pics taken 5/21/20 Please Read Below
    Engine
    Built motor and balanced rotating assembly. 4k on motor since rebuild. Teksid aluminum block, forged cobra crank, Manley pistons and rods. Heads rebuilt with new valves and seals & valve job. All new timing chains, tensioners, oil pump and arp bolts and hardware
    Motor has Stock compression and can handle way more boost then it sees. Engine is perfect w/ no leaks or issues and it was Built by a well known ford engine builder in the area (friend of mine). Engine looks new and timing covers and intake painted DSG.
    Ignition
    Msd Ignition coils w/ ngk iridium plugs
    Drivetrain
    T45 tranny w/ billet steel flywheel and OEM cobra clutch , OEM clutch cable and billet quadrant and firewall adjuster . Mgw shifter.
    2003/2004 cobra rear end w/ 430 gears (also have a set of 355 gears ) full tilt boogie tie rods and diff bushings and Diff brace.
    Turbo Kit
    On3 Gen 1 intercooled turbo kit Also have the forward facing Gen 2 kit ( not installed ) that will come with car .
    70mm Masterpower turbo
    Slp exhaust w/ 4" magnaflow tips
    All piping heat wrapped
    Fuel System
    2003/04 cobra fuel tank and pumps stock lines
    Interior
    Cypher racing seats with brackets and dual locking sliders
    Also have Stock seats
    Radio
    Pioneer head unit
    Raptor shift light
    Boost vacuume gauge
    Aem wide band gauge
    Tuning
    Ecu tuned by efi logics conservative tune at 6-8psi ( never any higher due to stock cobra pumps )
    Sct Big Mass air
    Sct X3 tuner w/ custom tunes
    Body and paint
    2003/2004 cobra bumpers , side skirts and side vents . Side skirt splitters .
    Rio Red and black two toned paint RM Paint/ clear.
    Kanen 3” Cowl hood ( have stock hood)
    Tinted Hedlights w/ 6000k HID ( have stock lights)
    Saleen wing and also have a trunk lid with 03/04 cobra wing
    Valve covers painted Rio Red w/ custom coil covers .
    Wheels & Tires
    18x10.5 & 18x9 Rovos concave rims w/ continental tires
    Suspension
    03/04 Bilstein shocks w/ qa1 coil overs and cobra springs in rear . Qa1 kmember and A arms .
    Maximum Motorsports full length subframe connectors
    UPR Heavy Duty 4 bolt Camber plates
    Brakes
    Powerstop coated rotors/ pads front and rear w/ professionally painted calipers
    Ive purchased this car back in 2008 from the original owner. In 2014 I had a tie rod break after hitting a big pothole and it the threw car into a ditch. Damage was to the pass fender / rocker and door/ a arm and tie rod but it was enough to total the car. Seeing that the damage was minimal I bought the car back from Insurance and built it into what you see here with oem parts . I worked for a body shop at the time and everything was done professionally and with care. Body & Frame was set up and measures , checked straightness and all body work done in house . All body parts installed were oem. For the past 5 years I have never re-registered the car bc I have a Dealer plate to drive it on. To register this car It will need to be inspected so check your state dmv laws. I also have a ton of stock parts and a Clean 2000 mustang GT Title and vin that will be included w/ the purchase from a doner car that I scrapped comes with car fax and both Vin Sticker and plate .
    I have put many miles on the car over the years since it was rebuilt back in 2014 . It drives perfectly w/ no issue and is a blast to drive. It has been my baby and im looking to give it to a good home. Just changed the oil and put a new steering rack and alignment in the car and re-did the cooling system .
    After a tough decision It is time to sell and move on. Please Contact me w/ any questions, and yes it is as nice as it looks in the pictures .
    I would also be interested in trade for a 2nd gen F150 lightning or a 2011 and up mustang GT.
    $14,000 or trade
    Located In CT
    Pm w/ questions or trades
    Junior Member Array tanguay's Avatar
    Jun 2020
    TX
    7
    Still for sale?
  4. Remove Advertisements
