Well thanks to some board members digiam42 for the cams and Kuestone for the valve springs I am going to attempt to change the cams and springs out,and add some long tubes and a Anderson ford power pipe. My question is has anyone succsesfully swapped cams without pulling the front cover off? If so can you give me some tips. Really dont want to pull the front of the engine down if I dont have to. Novi 2000 is kinda in the way. I know Anderson ford sells a tool for this but does it work? Thanks for any help Mike
what year is your car? its gotta be a romeo engine. if its not the cam gears dont unbolt and u have to take the front cover off.
yep its not that hard to pull the cover though. just be sure to line the chains up right
