Rick,
Can the 3.10 pulley be used with the stock belt and no addition of idlers without or minimum belt slip?
What do you recommend?
Tony
Senior Member
The 3.10 pulley has very little belt slip. If you don't want to use an idler you can also use a 3.00 sure grip pulley. This would work very well too. Either way you will be fine.
Rick
