Does the virgin 3.4 inlet still accommodate the EGR valve , and after it is modified ?
Yes----it still has the EGR.
I don't see why you couldn't run an Egr valve with any upgraded inlet. You would just need to make/modify the tube from the valve to the header. The valve would need to be moved from the back of the inlet to the side somewhere.
These inlets (when modified) are big!
Hpp Racing Modified 3.4 inlet
