Need Oil Supply Fitting for Oil Pan.
Results 1 to 7 of 7
    Default Need Oil Supply Fitting for Oil Pan.
    Hey guys-
    I ordered the MMR Oil pan and if you know it has the one fitting in the front of the pan for the Oil supply line. Well I want to know if anyone knows where I can get another one? I need it some what quick as I am on a dead line. If anyone knows please feel free to post up. Thanks again.
    I dont remember the size off hand, but your local speed shop should sell it.
    Awesome. That is as much as I thought, but I wasn't sure if it would be something rare to come across. Usually with my luck with I need the smallest of things they will be the hardest to come by. I guess I will swing by there when I can.
    Thanks for the help
  6. #4
    Senior Member Array T76Coupe's Avatar
    Mar 2004
    Winston-Salem, NC
    1,109
    I bought a typical fitting from the hardware store and works fine.
  7. #5
    Quote Originally Posted by blown302stng
    Thats true, you could use something from the plumbing isle to get you by...
  8. #6
    Well I went to Home Depot (Local Hardware Store) and all they had were Brass Fittings. I will need to try another store to try to find some NPT Steel.
  9. #7
    part of a "click" Array wiz's Avatar
    Jun 2004
    out front
    1,930
    try murrays speed and custom matt
  10. Remove Advertisements
  1. Would -8AN be too small for oil supply?
    By Stock4VGT in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-22-2009, 07:38 PM
  2. Coil Power Supply
    By 4pnt6 in forum 1996 - 2004 Mustang GT
    Last Post: 01-10-2009, 04:32 PM
  3. Fuel supply hinderance!
    By 169stang in forum 2005 - 2010 Mustang GT
    Last Post: 09-15-2006, 12:29 PM
  4. Fuel rail testport fitting size for fuel solenoid supply?
    By broke7 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-24-2004, 11:27 PM
