Man, while it's nice to have someone like Lethal Performance put everything in one bag for you and give you nice step-by-step cut here/solder here steps, the problem is- you don't know what you are looking at now.
When I did mine- it was more like, "OK I have a BAP now". KB said to wire it post-FPDM, so those directions were out. Went on Modfords and read up on a pre-FPDM install. Once you think it through, and understand how it works- it sticks with you. I installed my BAP 6 years ago and clearly remember every part needed and exactly how it is wired. Therefore I can easily troubleshoot it. I know where the input voltages are, how the relay wiring is setup, and where the ouput voltage goes. Those "cut and play" kits really do people a disservice- *especially* when modifying the factory electrical wiring setup.
