1 - 6 of 6 Posts
With basic bolt ons & stock eaton with 6# crank pulley would the combo above improve my 60ft over stock 3.55 & 26x12 slick combo I was thinking the combo above would be easier on drive terrain & improve my 60s.This same type of combo change on my fox bodied mustang had great results.
The simple answer is YES.
Same set up I run with great results, you will have to increase the rev limiter to just under 7k to make it across the line in 4th.
That doent sound right, my 4.10 28" tire combo crosses at 6300-6400 rpms. And yes it will help your sixtys.
I run the same combo and the last day of the season i got 1.57 60' with a 2.94 upper and 4lb lower.
1 - 6 of 6 Posts
