I don't need this converter anymore due to moving houses and lack of space. It is in new condition. It is a dirtydogperformance unit. Specs are below. It is rated for 4000-4200 stall. I have the same converter in my car and it is very streetable and great at the strip. Asking 650 shipped obo. If using paypal please add 2% to cover my fees.
Small pattern design with marauder front cover.
More than twice the OEM lockup surface with high carbon graphite clutch.
9.5 inch diameter
Safely rated for 7000 rpms and 450 RWHP.
Drain plug installed for easy servicing.
Furnace brazed pump with hardened pump drive hub and rigid balloon plate.
Roller type stator clutch for maximum street ability.
Furnace brazed turbine with tig welded tips for durability.
Sealed torrington bearing construction.
8 lbs lighter than stock unit empty and holds 2 quarts less fluid for less rotational mass.
Fluid balanced.
Damper style lockup piston for less abrasive application.
Discussion Starter · #2 ·
bump...price lowered to 600 shipped.
moving in a week. 560 shipped to your door. No paypal fees.
