Increasing CR vs boost pressure
Page 1 of 3 123 Last
Results 1 to 15 of 31
    Premium Member Array black2003cobra's Avatar
    Sep 2003
    Rochester, NY
    4,026
    Default Increasing CR vs boost pressure
    Edit 10/19/07. To whom it may concern. The source of the material below is me.
    Plagiarism = literary theft, or trying to pass someone else's words off as your own.
    For myths on copyright, please see Brad's web page: => http://www.templetons.com/brad/copymyths.html
    This question seems to come up time and time again. Is it better to increase the static CR or boost pressure. There are a couple reasons why supercharged or turbocharged engines run lower static compression ratios. A static CR in the range of 8-9 is very common. Here are a couple considerations.
    Consideration #1
    Heat from compression by a supercharger or turbo can be removed (for the most part) through use of an intercooler. Heat from compression within the cylinder cannot. Also, the cylinder pressure at the end of the compression stroke (prior to ignition) goes up exponentially with an increase in static compression ratio, versus a linear increase with boost pressure. Therefore, increasing the static CR is going to unavoidably push you closer to the knock limit for a given fuel. In other words, the octane requirement goes up more by increasing the static CR than it does by increasing boost.
    For example, increasing the static CR from 8.5 to 9.5 increases the temperature within the cylinder at the end of the compression stroke (but before ignition) by ~63°F, (assuming IAT2 = 130°F and ideal adiabatic compression with γ = Cp/Cv = 1.4. I won’t bore anyone with equations. The situation doesn’t change much even if IAT2 were only, say, 100°F. In that case, the increase in temp at the end of the compression stroke goes up by ~60°F for the same increase in static CR). Also, the pressure at the end of the compression stroke (before ignition) goes up by ~97 psi from 574 psi to 671 psi, assuming atmospheric and boost pressures of 14.7 and 14 psi, respectively. On the other hand, increasing the boost pressure from 14 to 15 psi increases the outlet temp of the compressor by only ~11°F, assuming AE=60% and IAT1 = 90°F. And by further assuming an intercooler efficiency of 80%, the increase in IAT2 is only ~2°F. Hence, the increase in temp at the end of the compression stroke will hardly change at all. Also, the increase in cylinder pressure at the end of the compression stroke only goes up by ~20 psi (from 574 to 594 psia) with this increase in boost pressure.
    So summarizing the effects of increased temp and pressure at the end of the compression stroke for the two cases:
    Increased CR from 8.5 to 9.5: ΔT = ~63°F and ΔP = ~97 psi
    Increased boost from 14 to 15 psi: ΔT = ~2.4°F and ΔP = ~20 psi
    A higher temp and pressure increase the likelihood of deadly preignition for a given octane fuel. And for those astute observers that know the physics I’ve applied, yes, although I’ve idealized things to keep it simple, (by not including effects such as heat loss thru the cylinder walls during the compression stroke or ignition and valve timing in the calculations), I’m sure they’ll also recognize that this doesn’t change the conclusion.
    Consideration #2
    Power is increased by two completely different mechanisms for the two approaches. Increasing the static compression ratio increases power via an increase in thermal-conversion efficiency. Increasing boost pressure increases power via an increase in mass-air flow rate. There’s less gain in thermal-conversion efficiency (and hence power) via an increased static CR compared to the power gain by increasing the mass-air flow rate via an increase in boost pressure. For example, increasing the static CR from 8.5 to 9.5 results in an increase in thermal-conversion efficiency (for an ideal Otto cycle) of about 3.2%. On the other hand, increasing the boost pressure from just 14 psi to 15 psi, increases the mass-air flow rate by about 3.5%. If boost pressure is increased by 2 psi, (from 14 to 16 psi), the increase in mass-air flow rate will now be more than twice that compared to the increase in thermal-conversion efficiency, (~7% vs ~3.2%), and ΔT and ΔP still won’t be as great as they are when increasing the static CR from 8.5 to 9.5. Therefore, not only can it be “safer” from the knock point of view, but a little more power is gained as well, (relatively speaking that is).
    In conclusion, I would contend that for a forced-induction application, that low compression is in general, the better way to go.
    Boost vs compression ratio Part II
    Since writing part I, there have been some comments made that I felt warranted a part II. Comments such as, “Good stuff, but peak combustion pressure and temperatures are far higher than they are pre-ignition.” Or, “I have more gauges than a pimply faced teenager in his Honda Civic, so I can run closer to the ragged edge.” Or, “The engineers didn’t put 8.5:1 compression pistons in the Terminator, or 8.4:1 in the FGT & GT500 for any thermodynamic reasons.” Or the classic, “It’s all in the tune.” Although most of these statements are not totally without substance, the basic conclusion is unchanged. Even though adjusting timing and AFR can reduce the tendency to knock, and although peak combustion pressure and temperatures post ignition are significantly higher than pre ignition, or in spite of how close one cares to run to the knock limit of a given octane fuel, (for a given fuel and AFR, etc.), the engine can make more power by reducing CR and increasing boost pressure, than the other way around for the same peak cylinder pressure. This is why it is common to see lower compression ratios on SI forced-induction motors. Obviously there are tradeoffs, however, as a direct result of the lower thermal-conversion efficiency. But when it comes to maximizing power and torque output at wide-open throttle for a given octane fuel, etc., lowering CR and raising boost pressure is the safer approach.
    This conclusion is based primarily on two basic facts:
    1. Mean-effective pressure (MEP) goes in direct proportion to the mass of air ingested, (which is directly related to boost pressure), but goes up “sublinearly” with compression ratio, CR
    2. To good approximation, peak cylinder pressure goes in direct proportion to both.
    And as mentioned in Part I, while heat from compression by a supercharger can be effectively removed through use of an intercooler, heat from compression within the cylinder cannot. As a result, peak combustion temperatures do not tend to rise significantly with increases in boost pressure, whereas they will go up with increased compression ratio. And as we all know, a lower peak combustion temp also reduces the likelihood of knock. One also needs to recall that power and torque are directly proportional to MEP, where the mean-effective pressure is defined as the “effective” pressure over the cycle, which is equal to the work generated over the cycle divided by the displaced volume. In other words, if the indicated MEP goes up X%, indicated power and torque will also go up X% at a given engine speed. Additionally, one needs to recognize that for a given octane fuel, AFR, etc., that as peak cylinder pressure and temperature are raised, eventually the engine going to knock, or detonate. This shouldn’t be any surprise since this is exactly how a fuel’s octane, (i.e. its resistance to knock), is measured. It is put in a special test engine whose compression is raised until the engine knocks. (The reference fuels used for comparison are iso-octane defined as having ON = 100, and normal heptane having ON = 0.) References: http://en.wikipedia.org/wiki/Octane_rating. Or section 6 here => http://blizzard.rwic.und.edu/~nordli.../gasoline.html
    For the ideal Otto cycle, it is very easy to derive expressions for the peak combustion pressure (P3) and temperature (T3), and mean-effective pressure. As in Part I, I’m not going to derive or show all the math, but simply get to the bottom line and show the results. For those that want the details, the interested reader is referred to any number of good text books on engine fundamentals, (Taylor’s, Heywood’s, etc.). I’ve also posted the equations, sans proof, in this thread: http://www.eng-tips.com/viewthread.c...=215499&page=1
    Taking the ratio of mean-effective pressure to peak cylinder pressure, or vice versa, one will find that the dependency on boost pressure drops out and the ratio only depends on CR for a given fuel and AFR. (Note - timing does not factor in simply because MBTT at TDC for the ideal cycle, but this does not change the conclusion.)
    where the thermal-conversion efficiency for the ideal cycle is given by, ηt = 1 – CR^(1-γ), cv is the constant-volume specific heat for the mixture, ηc is the combustion efficiency, Qhv is the fuel’s heating value, and γ is the polytropic exponent which can be taken to have a value of around 1.25-1.3, over the full cycle, (Ref., H.M. Cheung and J.B. Heywood, SAE paper 932749).
    Using these results, one can plot the ratio of indicated mean-effective pressure to peak cylinder pressure, iMEP/P3, vs compression ratio. From this plot, one will see that as CR goes up, the ratio iMEP/P3 will go down. (See plot below).
    What does this mean? It means for any given maximum tolerable peak pressure (for a given octane and AFR), that iMEP will be higher at a lower CR than at a higher CR, independent of boost pressure. Said another way, this means peak cylinder pressure climbs faster than indicated mean-effective pressure does as CR is increased, whereas both P3 and iMEP will climb at the same rate with boost pressure. Therefore, for any given fuel and AFR, etc., one can make more power & torque at any given engine speed by reducing CR and increasing boost pressure, than the other way around for the same peak cylinder pressure. The tradeoff is a lower thermal-conversion efficiency, which translates to a higher specific fuel consumption (pounds per hour per horsepower) and a “doggier” response at part throttle.
    Although the above conclusion was based on analysis of the ideal cycle, a more complete thermodynamic model including finite burn duration, heat loss, spark timing, etc, will show the same trends and lead one to the same conclusion. As an example, cylinder pressure and temperatures vs crank angle for two engines with the same iMEP, but different CR and boost pressures are shown below. As can be seen, the engine with the higher CR has higher combustion pressures and temperatures, making it more likely to knock for a given octane fuel.
    Boost vs Compression Part III – Measured data
    From posts in another related thread:
    Measured data, example 1, turbocharged Cobra:
    Let’s use the publicly available, actual data as posted on this web site. Using a turbo Cobra as an example, consider the data in the Terminator Summary of turbo data thread. (Link => Summary of turbo data)
    From this data, the "typical" turbo Cobra running 15 psi makes around 670 rwHP, (with stock displacement and CR.)
    Now say one increases CR to 10:1 from 8.5:1, and pulls a few deg of timing to avoid knock.
    How? Click link => Spark timing impact on knock
    Say this increase in CR nets a 6% gain as published in a recent magazine article. This then translates to 1.06*670 = 710 rwHP. So yes... a nice gain of 40 rwHP.
    But now lets keep timing at this same reduced amount, but instead of increasing CR, increase boost until one gets to the same peak cylinder pressure & temp. So how much boost is added? Use the well-known, effective-compression ratio as given by,
    CReff = CR(1 + Pboost/Patm)
    which comes about from how peak cyl pressure scales with both boost and CR. (Note – it also can take into account valve timing, by using the dynamic-compression ratio for the value of CR.) As Ed (eschaider) has pointed out, this effective-compression ratio is what VP (and others) uses to "rate" their various fuels.
    If one goes through the math, they’ll find that this would mean running around 20 psi at this same reduced timing, but with stock CR of 8.5:1, instead of 10.0:1. (Sorry...yes...a little math. The “prime” ( ' ) symbols indicate the “new” values of a quantity.)
    Pb' = [(CR/CR')(1 + Pboost/Patm) -1]Patm = [(10/8.5)(1 + 15/14.7) -1]14.7 = 20.2 psi
    Again from the regression analysis of actual data shown in the turbo data summary thread, (link provided above), the change in power with boost is roughly 22 rwHP/psi. So this means with the same reduced timing, the CR=8.5 motor with 20 psi would now be making 670 + 22*(20 - 15) = 780 rwHP. So a gain of 110 rwHP.
    Example from measured Turbo data - summary:
    Baseline case; CR = 8.5:1, boost = 15 psi, ~670 rwHP
    Higher CR; CR = 10:1, boost = 15 psi, ~710 rwHP
    Higher boost; CR = 8.5, boost = 20 psi, ~780 rwHP
    Measured data, example 2, twin-screw KB Cobra:
    Here’s a similar example of the same analysis for a blower car from chassis-dyno measurements made on the same car. (I didn’t have data at 15 and 20 psi, but I do at 17 and 23. Using the effective-compression formula given above, the higher boost would come out to 22.6 psi for this case, but I think you’ll give me the 0.4 psi.)
    For this analysis, the data is taken from the same vehicle, on back-to-back pulls, on the same dynamometer, and covers the full rpm range – not just peak power. Since it is from actual measured data, it includes all additional effects such as any potential belt slip, increased SC drive power, etc. Data for the CR=10:1, 17 psi case came by scaling the CR=8.5, 17 psi case up by 6%. (A worked example of how power scales with CR, including actual measured data, is given later in this thread in post #23, Link => Post #23.)
    As one can clearly see, the higher-boost/lower-CR makes significantly more torque than that of the higher-CR/lower-boost case, all across the rpm range.
    Boost vs Compression Part IV – Impact of valve timing
    From thread in 2011 Mustang Forum. Click link => Boosted Coyote Engines using VVT
    Yes, valve timing also has an impact and can reduce the risk of knock. One can delay the inlet-valve closing (IVC) event, which reduces the so-called dynamic compression ratio. Basically, when you delay the IVC, you aren't running as high a (dynamic) compression ratio anymore which as explained above, helps reduce peak cylinder pressure & temp, thereby reducing the risk of knock. Below is an example for the 5L Coyote engine in the new 2011 Mustang GT.
    Therefore, the engine calibrators can make use of the variable cam timing on the 5L Coyote engine to reduce its relatively high-compression ratio, to a lower compression ratio when using forced induction.
    Senior Member Array PhillyCobra's Avatar
    Jun 2003
    Northeast Philadelphia
    793
    Very nice, as always, Black2003.
    In your comparison, I assume the 2 different mods produce a similar increase in power at WOT? If not, please provide us with a comparison that can be expected to produce similar gains.
    Sep 2003
    Rochester, NY
    4,026
    Hey Philly – Of course it would ultimately depend on the type of compressor used (Eaton, KB, Whipple, or turbo). But for the most part, yes…the comparison of upping the static CR from 8.5 to 9.5 should give a similar increase in indicated power as going from 14 to 15 psi. (The relative increases were 3.2% vs 3.5%, respectively). In terms of brake power, a supercharger would definitely net you something less than the 3.5%, of course, but it would depend on what kind. Although it could be done, I didn’t bother calculating the increase in drive power. A turbo would probably see most of that 3.5%.
    7-5-08: Please ignore. Graphics below for in-line posting above.
    Last edited by black2003cobra; 07-05-2008 at 01:47 PM. Reason: Graphics for inline post added, as a test.
  6. #4
    Senior Member Array JT's Avatar
    Jan 2003
    1,818
    Very interesting.
  7. #5
    VMP Tuning Array Justin@VMP's Avatar
    Feb 2004
    Central FL
    2,911
    Default Re: Increasing static CR vs boost pressure
    Someone i know tried to put a 20psi blower on a 11.5:1 NA motor, they had good gas (C16) and very little timing but it still went all to pieces. Thats a good example of how too high of a CR is bad, no matter what the fuel.
  8. #6
    Senior Member Array MaxV's Avatar
    May 2006
    San Antonio, TX
    1,052
    From a practical standpoint (cars that will be driven on the street) I can vouch for not dropping compression too much. If you run an 8.0:1 motor on the street with an appropriate amount of boost, it will feel doggy off the line (before boost comes on). At least when it is compared to a 9.0:1 motor (even running a bit less timing).
    The thermal efficiency of the forced induction components also has a huge amount of importance when dealing with these cars. An Eaton (ported or not) is going to whip up IATs, forcing the intercooler/ heat exchanger system to do more work. Pulleying a thermally-challenged blower only compounds the problem. That is why 16psi from a Heaton does not equal 16psi from a KB or Whipple or even a properly-sized turbo. Luckily enough, that means you car run more boost AND timing from the bigger blower, and keep the oily bits inside the motor where they belong...
  9. #7
    Sep 2003
    Rochester, NY
    4,026
    FYI - Added Part II to keep this altogether in one thread.
  10. #8
    Moderator Array NeverEnuff's Avatar
    Nov 2006
    TX
    3,942
    Very good info and reading. thanks!
  11. #9
    Senior Member Array
    Jan 2004
    644
    Resurrection!
    Good info!
    Just my .02 though.....
    The scope of this information (atleast what I'm deriving) is "max power" with also references to pump fuel.
    Those who are using pump fuel are most interested in "street drivability/performance";
    I think when considering one extreme end of the spectrum, the other must also be considered.
    Can you make more power with 3000 CFM, and 6 to 1 compression. Maybe. Does that help a guy that is looking to put together the best compromize for pump fuel (and street performance). NOPE!
    With the scope of pump fuel and street driveability there has to be a happy medium, driving satisfaction vs. peak WOT performance.
    The happy medium is my holy grail at the moment as I decide on piston dish sizes
    I'll likely go with an 11.5 cc piston dish, and a thicker head gasket to net around 8.7 to 1 CR, (which I can change my mind and revert to stock gasket thickness and higher CR if desired).
    Although I do admit, if a car is doggy, this can be masked somewhat with gearing, auto-trans with loose converter, etc. It will still affect the drivability and satisfaction on the street.
    The bigger problem is enthusiasts who can't decide if they are driving, or racing there car, hahaha.
    Good info regardless!
  12. #10
    Sep 2003
    Rochester, NY
    4,026
    I’m glad you found the thread interesting, 4vMn12!
    The analysis actually applies to any fuel though. With any fuel, as peak cylinder pressures and temperatures are increased, the engine is eventually going to knock. Again, this is basically how a fuel’s octane rating is measured and is what determines the octane requirement of the motor.
    As was mentioned, and as you are apparently aware, there are tradeoffs under part throttle (no boost) when reducing the static compression ratio of the motor. This is due to the drop in thermal-conversion efficiency, ηt, which is a very non-linear function of compression ratio. To help illustrate this, one can see from the graph below that ηt really starts to drop off quickly at lower CRs, and approaches zero when CR = 1. (This is simply because the gas is no longer doing any work on the system when CR ≡ Vd/Vc = 1. In other words, at CR = 1, work = 0, and hence, ηt ≡ work/Qin = 0.) Clearly such low compression ratios are to be considered extreme cases, however, as they are not exactly practical nor appropriate with modern fuels and engine designs.
    The value you have chosen for you motor is quite typical. Thanks for your input!
  13. #11
    Senior Member Array mustangjohn's Avatar
    Dec 2005
    San Antonio,TX
    1,687
    Great info! I bumped my compression some becuase i couldnt raise boost any more since i was sticking with a already max pullied ported eaton. While rebuilding the short block i had to buy pistons anyways so it was sort of like free power. If i was going TS or turbo i never would have changed the comp ratio.
  14. #12
    Feb 2004
    Central FL
    2,911
    Bumping CR is one thing I look at, if I ever build a motor for my GT500.
    Also, as E85 becomes more available, it starts to look like a real good option for higher CR blown street cars.
  15. #13
    Senior Member Array 03yllwcobra's Avatar
    Nov 2005
    Greenville, SC
    1,396
    so does this mean i messed up upping my CR From stock to 9.4:1 for my f1a? =(
  16. #14
    Senior Member Array Ninesecsnake's Avatar
    Sep 2005
    South Dakota
    385
    Quote Originally Posted by 03yllwcobra View Post
    No you made the right choice. Keep good gas or E85/98 and you'll be fine. Mine is over 10:1 and we have zero issues with big turbos. I do use E98, but results are similar with E85 also.
  17. #15
    Nov 2005
    Greenville, SC
    1,396
    Quote Originally Posted by Ninesecsnake View Post
    i dont know if i have enough pump/ injector for e85, i have dual GT Pumps and a BAP with 75lb injectors.
  18. Remove Advertisements
  1. Increasing compression instead of boost?
    By jeffs in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-18-2010, 07:38 AM
  2. Boost And Fuel Pressure
    By FLYER in forum 1996 - 2004 Mustang GT
    Last Post: 04-09-2007, 06:11 AM
  3. Increasing TQ???
    By purevil in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-24-2006, 01:27 PM
  4. Common tuning changes when increasing boost?
    By johnny-longtorso in forum 1996 - 2004 Mustang GT
    Last Post: 02-12-2006, 10:10 AM
Tags for this Thread
