Whipple Belt sizes
Page 1 of 6 123456 Last
Results 1 to 15 of 88
    Senior Member Array highoctane's Avatar
    Oct 2005
    NC
    4,398
    Default Whipple Belt Size Reference
    OK, I see alot of Whipple belt size questions popping up so maybe we should start a thread on it, I'll start.
    Stock Lower 3.5 upper, stock idlers- NAPA/Gates part # 080760
    Stock Lower 3.0 upper, 4 piece BF idlers- NAPA/Gates part # 080774(probably could stand to be about 1/4"-3/8" shorter but was the closest I could find at NAPA)
    3.50 upper, 2lb lower, stock alt pulley, 4 BF idlers, lower idler in upper position on bracket 080820
    3.50 upper 4# Lower, stock idlers, 3.20 Alt pulley 79.7" Gates
    3.25 upper 6# lower whipple tensioner & 3.5 alt pulley # 080866
    3.00 upper 6# lower, stock Alt pulley, 3 BF idlers (no snub), lower idler upper position 080810 (tight fit could be a little bigger)
    3.00 upper 6# lower, stock Alt pulley, 4 BF idlers, lower idler upper position, 080825
    Good idea.
    Quote Originally Posted by highoctane
    Rod
    Thanks man, I've been trying to track down the size I'll need for my 3.00 upper, stock lower, and BF 4-Idler set. The Gates#080774... is that 77.4"?
  6. #4
    Oct 2005
    NC
    4,398
    Quote Originally Posted by DSGCOBRA03
    It is 77 7/8" , Don't ask me how they come up with the 774, lol.
    Rod
  7. #5
    Senior Member Array BurnTire's Avatar
    Oct 2004
    Pittsburgh, PA
    1,263
    Is this with the new or old billet flow snub bracket?
  8. #6
    Senior Member Array StangRacing's Avatar
    Feb 2004
    Hattiesburg, MS
    809
    I was told to get 76.5 gates for
    the 3.0 upper and 4 pic BF idler with new snub bracket.
    I ordered it will come in WED......I guess I will see then.......
    I was told this combo by 2 people that have on their Car.
  9. #7
    3.25 upper 6# lower whipple tensioner & 3.5 alt pully 080866
  10. #8
    Oct 2005
    NC
    4,398
    Quote Originally Posted by StangRacing
    Let us know if it fits, I had a 76" belt laying around and it wasn't even close with the same set up , I could go a little shorter, but a 76.5 would not fit on my car unless i broke off the tensioner tab. I think a 77 1/2 would be perfect.
    Rod
  11. #9
    Oct 2005
    NC
    4,398
    Quote Originally Posted by BurnTire
    New.
    Rod
  12. #10
    Oct 2005
    NC
    4,398
    Quote Originally Posted by ds03cobra
    Thanks, I added this to my original post. Once I get some more interest/info I'll make a spreadsheet and post it up.
    Rod
  13. #11
    Feb 2004
    Hattiesburg, MS
    809
    76.5 no way.......almost fit if I took off the idler pulley but even then.
    going to Napa and try the 77.4
    thanks
  14. #12
    Senior Member Array
    Nov 2005
    cleveland
    122
    OK, I finally found a belt so I will post up here.
    Setup
    new whipple.
    3.5 upper / 4lb lower.
    all BF idlers with new style snub.
    3.2 alt. pulley
    stock notched tensioner
    84 3/8............
    I forgot the Gates # so I will post that up later. Took me awile to get the right fit. This size does not seem to go along with what others have for similar setups but it seems to be perfect on mine.
  15. #13
    Oct 2005
    NC
    4,398
    Quote Originally Posted by FLYtime
    Setup
    new whipple.
    3.2 alt. pulley
    84 3/8............
    Which position do you have the lower idler in? I think there 2 places to put the idler depending on what lower you have? That could be the difference I believe.
    Rod
  16. #14
    Probably the upper position if he is using a longer belt than others have used with the same setup.
  17. #15
    Senior Member Array
    Nov 2005
    cleveland
    122
    Quote Originally Posted by BlackSabbath
    Yup, got it in the upper position.
  18. Remove Advertisements
  1. Whipple pulleys/belt sizes
    By Blwn04cobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-30-2010, 08:33 AM
  2. KB belt sizes? 3.5/2lb & 3.5/4lb
    By LTHL VNM in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-22-2009, 12:56 PM
  3. Belt Sizes
    By NITROS COBRA in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-07-2008, 08:12 AM
  4. Are 2.8 and 2.6 belt sizes the same?
    By mpe331lx in forum Kenne Bell Tech
    Last Post: 05-06-2008, 06:41 PM
  5. whipple belt sizes
    By HFD_20 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-11-2006, 12:38 AM
