KB stock tune or SCT custom?
Results 1 to 9 of 9
    Default KB stock tune or SCT custom?
    Hi Guys,
    I'm already running the KB stock tune 8 psi and the car is running great on 91 oct, has advertised we saw 25 degrees of timing on the first dyno check run and 23 on the second.
    I have no throttle response issues, the stout hot street car goal has been reached, it is a monster
    I'm debating if I should have it cutom retune at 17 degrees and 11.8 A/F for hot weather (next summer) safer detonation margin, also thinking about a bigger intercooler with dual fans.
    Need your feedback on this, thanks.
    Default Re: KB stock tune or SCT custom?
    Quote Originally Posted by rog06gt View Post
    Hi Guys,
    Have you read the details on the KB tune on KB's site? It has some details you should consider concerning A/F ratios, and timing. Also consider where you are reading the A/F ratio, wideband, or tailpipe, their will be a difference. Not steering you either way, but be sure to be fully informed on which method really has more margin for error.
    Im Not Banned...yet Array 94tbird's Avatar
    Mar 2006
    Nanuet, NY
    5,362
    i have a custom tune, a custom race tune, and kb's tune. i run kb's tune on the street for al ltypes of daily driving. i run the race tune at the track. i never even touch the regular custom tune anymore. the KB tune is dead on even with the high timing. as long as your not seein or hearing pinping or knocking you good. also would consider moving to 93 octane if its avalible where you are. jsut an added protectino against pinging and knocking over 91
  6. #4
    My opinion is get a custom dyno tune no matter what. I personally have had bad experiences in the past.
  7. #5
    Senior Member Array jgorm's Avatar
    Jan 2005
    San Diego
    612
    Quote Originally Posted by StealthAuto View Post
    I also had bad experiences with the KB tune. But if its good, then you are ok, but get a wideband and keep an eye on it and listen for detonation.
  8. #6
    Senior Member Array
    May 2006
    NC
    1,320
    I love KB's tune. I am currently running it, and plan to keep running it untill I build my motor.
    I also see 25 degrees of timing up top on a cold pull, but im not worried as I have confidence in KB's tuning ability.
    I have also changed my pulley and upped the boost to 10lbs. and I am still running their tune. The A/F ratio stayed spot on too!
    On the stock/slightly modified motor, I feel like spending the money to get a custom tune is a waste, at least with the KB kit.
    Josh
  9. #7
    Mar 2006
    Nanuet, NY
    5,362
    Quote Originally Posted by Josh @ PMP View Post
    Josh
    +1
  10. #8
    I am running the KB tune and have to be very careful in hot weather to avoid ping. Occationally I get a bad tank of gas and it can be a problem. When I do get ping it's usually not in boost, but right after shifting when the rpm's drop. Of course I get right out of the throttle. If it did happen under boost though...
    It didn't seem to make any difference in the ping whether I was at 8psi or 9psi. I don't want to back off the timing, actually want to increase to 12psi, and have installed a snow water/meth injection to get rid of the ping.
    Hopefully I will get time to dial in the snow kit soon and will post results.
  11. #9
    Thanks guys, I can read between the lines, I'll keep the KB tune and invest in a gordsford performance heat exchanger with dual electric fans, when the air temperature is going to be hot & muggy I'll switch to 94 oct.
  12. Remove Advertisements
  1. custom tune...
    By ilbehaved in forum Tuning and Diagnostics
    Last Post: 01-13-2006, 02:23 PM
  2. custom tune
    Last Post: 09-19-2005, 10:02 PM
  3. Do I need a custom tune?
    By jjtgiants in forum Tuning and Diagnostics
    Last Post: 07-06-2005, 08:48 AM
  4. Will I need a custom tune?
    By zmon33 in forum Tuning and Diagnostics
    Last Post: 05-05-2005, 08:02 AM
  5. Stock Pulley + Custom Tune = ?
    By metaman in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-22-2004, 05:51 PM
