KB 810 HP/ 745 ft/lbs Shelby GT500 kit - Page 3
Page 3 of 4 First 1234 Last
Results 31 to 45 of 50
  1. #31
    Senior Member Array Jim Ferraro's Avatar
    Feb 2004
    Orlando, FL
    861
    Default Re: KB 810 HP/ 745 ft/lbs Shelby GT500 kit
    Quote Originally Posted by smpmustanggt05 View Post
    nice...
    how come on the dyno chart the lines are not smooth...does the tune need some cleaning up?
    That's pretty normal for a dyno chart when graph "smoothing" is not turned on.
    PS: It's "Axle", not "Axel" =o)
  3. #32
    Junior Member Array
    Oct 2006
    Dearborn
    20
    Quote Originally Posted by dun4791 View Post
    It sure would be fun finding out..............When it breaks, build it better.
    And better and better.
    That is just amazing! Great job!
  4. #33
    You guys are makin some power..
    Question?
    The GT500 comes with 50-52lb injectors from factory (They are 50lb, but ford racing says 52lbs.. whatever) The photo of the orange car has factory injectors. How are you making 800whp with 50lb injectors? By My calculations you would need 80+PSI of pressure with 19psi of boost and 800whp (at 100% dutycycle), personally I dont see that working very well. The injectors are fine with that (The pressure, not the 100% duty cycle), but its the fuel pump, at 80-90psi it cant be happy with 800HP, im sure you guys have a boost-a-pump on it but still, problem is the pressure.
    You can go to a 60lb, but then the problem is idle with the 48mm Stage 2 SRT Injector, the spray pattern sucks for 4v per cyclender. Also I dont think the car has room for a standard tall injector because of blower inlet clearance, but I have not tried.
  6. #34
    Kenne Bell Superchargers Array KC@KB's Avatar
    Nov 2003
    874
    Quote Originally Posted by BigBill View Post
    Question?
    Hey BigBill.
    Thanks for your comments.
    At Kenne Bell, we always test the limits of each component in the system; injector(s), fuel pump(s), inlet system(s), intercooler(s) etc.. We run literally hundreds of tests, very meticulously, only changing parts as we need them, recording all the necessary data to back up the results. When we change anything, we change only one thing at a time, then run more tests to check those limits. We never said running 800 rwhp was OK to do everyday with this set-up. Yes, the pressure was high, and yes the injectors were maxed out, but we did make it - 810 rwhp.
    Our recommendations will all come out in our Tech Tips on the Shelby GT on our website. Everyone will be able to see where the limits are then.
    Regards,
    Ken
  7. #35
    Premium Member Array black2003cobra's Avatar
    Sep 2003
    Rochester, NY
    4,026
    Jim - Sounds like you guys might have what I've been looking for in the way of data...the flow rates vs pressure ratio or pressure drop across these factory intercoolers. In particular, I'm looking for data for the '03 Cobra, but would also be interested in the results for the GT500 and Ford GT. Thanks in advance.
  8. #36
    Saw the car at LACR on a Slip and Slide Night / Friday.
    Not sure why, but why is Earl dumping the clutch on Drag Radials? Anyways the best it ran was 11.55 @ 125mph...not bad for having driveability issues with some sort of fuse blowing.
    Maybe Earl and Gene can take it out a little more often to get some respectable ET's.
  9. #37
    Yeah... I got some.... Array chuckles's Avatar
    May 2005
    Albuquerque, NM
    2,215
    well, the 125 trap should put her deep into the 10's. No traction?? probably blew the fuel pump fuse...
  10. #38
    Senior Member Array
    Mar 2006
    Rancho Cucamonga
    761
    The information is up on the website now.
    Shelby GT 500 Supercharger Kit
    Thank you,
    James
  11. #39
    Senior Member Array stangfreak's Avatar
    Jul 2003
    long island, new york
    6,191
    Quote Originally Posted by chuckles View Post
    a125 trap will not put you deep into the ten's
  12. #40
    Senior Member Array Boosted98GT's Avatar
    Dec 2003
    Terrorizing Ricers in Southcentral PA
    8,894
    Quote Originally Posted by [email protected] View Post
    Thank you,
    James
    Thanks James!
  13. #41
    Ken/James (and Dustin),
    You can see by my number of posts that I am not a major contributor to these boards. It's not because of my lack of passion, rather I do not possess the technical/engineering expertise the rest of you have. But I had to take the time to commend you on the thoughtfulness of your posts and the fact that competitors engage in a healthy exchange to better the products for your consumers.
    The intellectual capital shared here is exactly why I come to ModularFords.com versus the other forums.
    It's this type of exchange that creates goodwill with consumers, and this is exactly why I will be a Kenne Bell customer for life.
  14. #42
    Member Array
    Apr 2006
    Las Vegas
    71
    With a 5.87 psi drop through the intercooler do you have plans for an upgrade from the stocker?
    The restriction probably has a big effect on cooling the charge also?
  15. #43
    I thought 600whp was the limit for the rods?
  16. #44
    Quote Originally Posted by shelbyn08 View Post
    I have heard 650 as the limit on stock internals but I would like to know some hard facts on this as well. Thus far all I have read seems to be more hear say. Anyone have more info on this?
  17. #45
    So can any of the experts tell me what a 100% safe power level is for a stock motor? 4.6 and 5.4
    I'm planning on putting together a 06-07 Stang with a intercooled SC(most likely a KB). I just am unsure how I want to tackle the mision. I would like a 450-500rwhp daily driver on 92-93 pump.
    My 2 options are:
    1. get something like a Roush SC and just upgrade everything to attain desired results.
    2. get a GT 4.6 and build it up from scratch.
  18. Remove Advertisements
  1. My Shelby GT500
    By JerseyGator in forum Pictures and Videos
    Last Post: 10-24-2009, 07:29 PM
  2. Shelby GT500 help
    By R3dF!r3 in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 09-08-2007, 12:38 PM
  3. 07-Shelby GT500 Bra
    By RustyH2O in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 12-21-2006, 02:18 PM
  4. New #s for Shelby GT500 w/ KB 2.8H!
    By 04MystiCobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-17-2006, 08:20 PM
  5. 07 shelby gt500 for $600,000
    By gunslinger in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 01-26-2006, 01:43 PM
