"H" vs. non "H" comparison
Page 1 of 2 12 Last
Results 1 to 15 of 21
    Default "H" vs. non "H" comparison
    New Kenne Bell "H" series 2.0 Pressure Ratio Design. Up to 60 HP
    Kenne Bell continues to lead the pack. 6 months of testing on our dyno and with select shops has resulted in a brand new Twin Screw for the 2v, 3v and 4v Ford engines. The revolutionary "H" series(2.6H and 2.8H with 2.0PR) are now tested proven and available. Recommend for higher 15-24 psi boost applications only. Power gains are up to 60 hp over "conventional" 1.4 PR(pressure ratio) 2L Twin Screws. Charge temps are also up to 30 degrees cooler. Here's the best part, all of this at the SAME BOOST and SUPERCHARGER RPM. To understand the significance of this breakthrough consider this. It would require approx. 4 more psi boost, 70 degree higher charge temp, about 1/2" smaller pulley and another 2000 supercharger rpm for a "conventional" old design 1.4PR Twin Screw to match the new KB 2.0 PR concept.
    The latest KB 2.8, 2.6 BIG BORE billet superchargers were already the largest displacement and more effecient Twin Screws we ever tested. Now we've added the "H" series. The 810 HP '07 Shelby GT500 dyno run that shocked the industry would not have been possible without the new 2.8H. The secret is out. Check out the back to back dyno comparison between our 2.8 (1.4PR) and 2.8H (2.0PR). A whopping 60 HP with the SAME pulley, boost, tune etc. Only the supercharger was changed. The car is 100% stock except for our 2.8 H kit with Boost A Pump and Cool Air Kit.
    Recent ST Motorsports tests on their '06 4.6 700+ HP Mustang for 5.0 Mustang Magazine indicated a big 32 HP gain in a back to back 2.6 vs. 2.6H comparison. Check out our website Dec 7 for more info on the "H" series.
    Senior Member Array saleen556's Avatar
    Dec 2004
    Banks ,OR
    582
    Default Re: "H" vs. non "H" comparison
    Thanks KB ..
    Snake Charmer Array Shadowgray03's Avatar
    Apr 2003
    Minnesota
    2,830
    Ugh! See, now you guys have to come up with a trade in program. Ive got a pristine 2.4 with about 2k miles on it and you go and come out with this
  6. #4
    dec 7 has come and gone.When will there be new info?
  7. #5
    We should hopefully have it up by Monday.
    Thank you,
    James
  8. #6
    It's up on the website now.
    BIG BORE Supercharger
    Thank you,
    James
  9. #7
    Senior Member Array 2vkiller's Avatar
    Dec 2005
    Indiana
    247
    Is there a price difference in the H or non H blowers? I want a 2.6H for my 2v and you website did not list an H blower. Thanks
    Chris
  10. #8
    Nope no price difference. Just let the saleperson know when you order the kit.
    Thank you,
    James
  11. #9
    Senior Member Array
    May 2006
    NC
    1,320
    This is great guys! You never cease to amaze me....
    Hopefully Ill get a motor dropped in my car soon and Ill see about picking up a an H model blower for my car.
  12. #10
    Quote Originally Posted by Josh @ PMP View Post
    you sell whipples and saleen SC's and your getting a KB? whats wrong (or right) about this picture?? I love KB but arent you sending mixed signals to your customers??
  13. #11
    oh wait i just saw farther down you sell Kb's as well sorry
  14. #12
    Senior Member Array BlownBlu97's Avatar
    Feb 2003
    Cortlandt manor
    5,420
    I purchased my new 2.8L about a month ago but I did't specify an "H" because I was told that all the 2.8L's were the H style.
    Is this true?? I hope do to that an H model is the one I want to have on my new motor. How can I tell by looking at the unit? I read that it has a H patten on the discharge as opposed to the older triangle style but looking at it the inner plate by the rotors is a triangle shape but the aluminium base has the H shape.
  15. #13
    Click on the link and it will show you.
    Thank you,
    James
  16. #14
    Senior Member Array TREESE's Avatar
    Jan 2005
    Tri-Cities, Wa.
    768
    Quote Originally Posted by BlownBlu97 View Post
    An H pattern? Wow, strange. Thats how these stories get started. The H is for high pressure, meaning that the screws mesh for a greater length and thereby create a greater internal pressure before the discharge opening. This equates to greater efficiency at higher boost pressures. Below is from the Kenne Bell site. The discharge plate is the same to the best of my knowledge. James correct me if I am wrong.
    There is now a big difference in Twin Screw superchargers. The longer compression distance between the inlet and outlet results in a higher “Internal” Pressure Ratio (2.0) for the “H” and a 15-24 psi efficiency range. The “S” uses a 1.4 PR which consumes less engine HP and cooler air charge temp in the 6-14 psi range. Minimum recommended boost for the “H” is 12 psi.
    Note: The “H” and “S” Series superchargers are identical in construction and boost output. Only the “H” discharge port shape is revised to lower air charge temp and reduce parasitic loss (engine HP to drive supercharger) at 15 psi and higher boost levels (See Tech Info and Dyno Tests).
  17. #15
    Feb 2003
    Cortlandt manor
    5,420
    It is right in the new 5.0 mag about how it has a new H patten now but from what I see it is still the same shape just smaller. I also see that mine is an "H" do to the smaller dicharge area.
    If you get a new issue of the 5.0 mad on page 126 there talking about the 2.8 on the shelby and they stated and I quote from the mag:
    "while the "H" in the 2.8H's ID techinically stands for high pressure ratio, the base/discharge has a "H" patten as opposed to the triangular-shaped discharge outlet that has been more commen on screw style blowers"
    This is what threw me!
    One more question?? I was under the impression the new 2.6 and 2.8L's took less HP to drive. Now if it is an "H" style the HPloss from driving the blower increases over the "S"??
  18. Remove Advertisements
Page 1 of 2 12 Last
  1. "oil life" reset & "vehicle health" del.
    By Vintage Racer in forum 2005 - 2010 Mustang GT
    Last Post: 04-21-2010, 09:50 PM
  2. "Help" Added LT's to my 2.4, and now lost Hp and boost "WTF"
    By j'svtcobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-31-2007, 01:01 PM
  3. New "blower only" and "nitrous" Best! Finally got my 9sec slip!
    By Sprayed_Snake03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-24-2006, 05:28 PM
  4. Can someone explain the differences in "hotter" and "colder" plugs?
    By 99-LS1-SS in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-25-2004, 01:05 PM
  5. Another Intercooler "Chiller" Powered by "Freon" (HC-134)
    By oldmodman in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-22-2004, 06:30 PM
