03/04 Cobra Block VS Cast Iron PI (mustangGT) block
Results 1 to 6 of 6
    Senior Member Array StangRacing's Avatar
    Feb 2004
    Hattiesburg, MS
    809
    Default 03/04 Cobra Block VS Cast Iron PI (mustangGT) block
    What are the diff between a
    03/04 Cobra Cast Iron block vs Cast Iron PI block
    Just block not asking bout the internals.
    thanks
    Senior Member Array
    Mar 2004
    Tempe, AZ
    1,193
    Default Re: 03/04 Cobra Block VS Cast Iron PI (mustangGT) block
    Don't think there is a difference. There is a difference between the romeo and windsor blocks though. Not sure which is which, but one is supposedly stronger and one that has larger bolt holes for the timing cover. Again, not sure which is which.
    Senior Member Array James Parker's Avatar
    Jul 2003
    Mobile, AL
    8,192
    The Windsor block has the larger holes. Same on the heads (i.e. the Lightning power steering pump bracket holes). You can tap the Romeo blocks to work in a Lightning, however. The heads you'll just have to find some smaller bolts for that bracket (no biggie). Also, the Windsor heads have more valve cover bolt holes.
  6. #4
    Member Array Jonathan White's Avatar
    Mar 2005
    Laurel, MS
    69
    What about a difference between a non-PI motored block and an 03-04 cobra block? Any major differences?
  7. #5
    Feb 2004
    Hattiesburg, MS
    809
    Thanks James for info.
  8. #6
    Senior Member Array
    May 2003
    San Jose, CA
    388
    Quote Originally Posted by Jonathan White View Post
    From the SHM Book:
    "The major difference between the two is the main bearing caps and the main bearings themselves. Each of these engines uses different main bearin sets that are not interchangable. The 99-01 main cap uses one time only torque to yield bolt. The cap fits snugly between the case sides. The 93-98 main cap uses a jack screw in the side of the engine case to preload the side of the main cap, while a side bolt through the center of the jack screw secures the assembly. The side bolt on this model is reusable."
  9. Remove Advertisements
  1. Brand New 04 Cobra Cast Iron 4.6 Block $
    By Blacksnake in forum Engine Parts
    Last Post: 06-28-2011, 03:53 PM
  2. Brand New 04 Cobra Cast Iron 4.6 Block
    Last Post: 11-28-2010, 01:57 PM
  3. New 04 Cobra Cast Iron 4.6 Block $400
    Last Post: 11-03-2010, 10:35 PM
  4. Cast iron block
    By svtsnake04 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-10-2010, 05:42 PM
  5. cast iron Windsor WEP block
    By JVENOM in forum 1996 - 2004 Mustang GT
    Last Post: 02-12-2006, 10:55 AM
