Bridge Racing 4.6L Mod Motor (True 281 ci.) Alum. rods, 90mm accufab throttle body, sheetmetal upper intake, fuel rails, 160 lb bosch injectors, JE Pistons, trap door style Alum. oil pan, Heavily worked '99 Cobra cylinder heads, Bolt on Bridge distributor drive system, MSD plug wires, motor plates, Peterson external wet sump pump & drive kit, alum. water pump block off.
Engine has only done 1 event since being freshened -- New block, JE pistons, Total Seal rings.
Engine went 7.9's with a cast wheel GT4788, stock suspension Mustang weighing 3100 lbs.
$10,600.00
Please send questions to [email protected]
662-280-7755 Southaven, Mississippi.
$10,600.00
