New Setup Questions
Results 1 to 5 of 5
    Default New Setup Questions
    I've narrowed things down to two possible setups and I'm looking for opinions on which one would be best and fastest on a stock motor car. This is with all supporting mods except for the motor being built.
    Setup 1. Hellion 76mm turbo w/ spray. I would run around 25+psi and maybe a 100-150 shot through it on race gas.
    Setup 2. KB 2,8 w/ spray. I would run again about 25 psi and 100-150 shot through it on race gas.
    So which setup will be fastest (not quickest)? Does anyone have any other suggestions apart from a twin turbo setup that would push a big amount of power? Would it be possible for me to beat (or just not get completely walked) by an 1100hp supra with a bad driver on either setup? Are there any guesses as to how much power these setups can make?
    I'd appreciate any ideas anyone has. Thanks guys.
    Default Re: New Setup Questions
    If the psi is equal, turboes, make more power most of the time.
    Senior Member Array xtremejc's Avatar
    Oct 2002
    Frisco, TX
    1,067
    I will go against the grain and say that the twin screw @ 25psi + 150 shot of sauce setup will be faster than the single 76mm turbo + spray given that the cas can both hook up. The TS car will make way more torque over a broader rpm band which is what this heavy cars need to get them going hard...
  6. #4
    Senior Member Array James Parker's Avatar
    Jul 2003
    Mobile, AL
    8,192
    I've dyno tuned both combos multiple times. I was comparing a couple of customers lately. One has a Hellion at 21 psi, and the other a 2.8H at 21 psi. They are basically identical in power from 5k on up, but from 1500 to 4.5k the 2.8h DESTROYS the Hellion. Fun factor = KB!
  7. #5
    Senior Member Array crazzylegs's Avatar
    Oct 2003
    virginia
    142
    Quote Originally Posted by RWTD View Post
    No offense, but the 2.8 is not better than a hellion 76. I have dynoed and ran both, and hellion always makes more power than the kb and out runs it at the track, which is what matters. A turbo will always make more power than a blower at the same boost, if its tuned right, always. Plus the hellion kits make 25 + pounds! Kbs are nice, but a turbo is the way to go. I will line up a 2.8 and smoke it every time. If you want to play put on an 88mm.
    Mike
    1-804-894-1144
  8. Remove Advertisements
  1. N/A setup questions??
    By john2424 in forum 1996 - 2004 Mustang GT
    Last Post: 08-23-2009, 12:10 PM
  2. setup questions
    By BJs03GT in forum Vortech Superchargers
    Last Post: 03-08-2009, 06:01 PM
  3. Questions on my new setup with the KB 2.8L H
    By BlownBlu97 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-19-2007, 11:41 AM
  4. 2.93/4lb setup questions?
    By venomousSB03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-05-2005, 01:16 PM
