Mach 1 Combos/Times
78K views 71 replies 46 participants last post by  eruza
#1 · (Edited)
Come on you Mach 1 guy's....post up your combos and times for other people to shoot for.
I know some of you have some sick Mach's....let's see the #'s.
You road race guys are welcome also, you guy's are over shadowed a lot buy the drag guy's. Here is a combo/times thread for you also.
:cheers: :ilovemf: :ilovemf: :ilovemf: :cheers:
Format:
Name
Make/Model/Year
Track Name
Time
Modifications
Sponsors
#4 · (Edited)
Make/Model/Year: Ford/Mach 1/2003
Track Name: Cecil County Dragway
Time: 11.354 @ 119.94 mph (Naturally-Aspirated)
Modifications:
Engine:
Dyno Tune
EGR Delete
PHP Intake Spacer
Electric water pump
Custom-Made Cold Air Kit
Ported Mach 1 lower intake
Polyurethane Motor Mounts
Driver-Adjustable Two-Step
Alternator & p/s Underdrive Pullies
NX 100 or 125-shot w/Safety Accessories
Exhaust:
SLP long-tubes
SLP catless X-pipe
Magnaflow Catback
Weight reduction:
A/C Delete
No Passenger seat
Lightweight Battery
Lightweight driver seat
Self-Made Rear Seat Delete
Rear Mach 1 Sub Box removed
No front sway bar, jack, spare tire
Trunl Panels & Underhood liner removed
Front & rear bumper support brackets + foam removed
Stock radio/CD player replaced w/aftermarket gauges & panel
Tires/Wheels:
M/T ET Drag slicks
Moroso DS-2 Front-Runners
Centerline Warrior 15" Wheels
(15" X 4" & 15" X 10")
Transmission:
Fidanza Aluminum Flywheel
Mcleod Clutch & Pressure Plate
Pro-Motion TKO Shifter (Steeda-Made)
26-Spline TKO 500 Trans (Face-Plated)
Adjustable Clutch Cable & Firewall Adjuster
Suspension/Chassis:
MM Full Length SFC's
MM Caster/Camber Plates
MM Adjustable anti-roll bar
AJE Tubular K-member & A-Arms
Welded Torque Boxes/Axle Tubes
Front Coil-Overs with 175lb springs
Adjustable Drag Struts & Drag Shocks
Adjustable rear upper/lower control arms
Rear:
4.56 gears
33-spline Moser Axles
33-spline Moser Spool
T/A Cover with bearing cap supports
Misc:
SLP Line Lock
Manual Fan switch
Programable/Recording Shift Light
Sponsor: My checking account
A video of my best N/A run can be found HERE.
#5 · (Edited)
Name-Shane Baker
Make/Model/Year-Ford Mach 1 2003 Black Automatic
Track Name- Speed World Phx AZ
Time-12.6@112.1 W/2.0 60ft (before Billet T/C and built trans)
Modifications
Billet T/C 3500stall and built trans from BC Automotive
Bass. cat back
Mac o/r h-pipe
K&N filter
C&L tube only
3.90 gears
Nitto DR's
Small shot on the bottle
NGK TR6 plugs
SCT switch chip (custom tuned by Devin @ Performance Solutions)
UCA
FSB removed
Sponsor-Performance Solution
#15 ·
UPDATE:
I ran a 12.304 @ 112 with a 1.85 60' time last weekend on a 100 shot!!!!!!!!!!!!! Heading back out this weekend to hunt down that 11sec slip. I left a lot on the table on that pass, I don't plan to leave anything on the table this wekend.
#7 ·
'03 Mach1 5spd.
Track: Bradenton Motorsports Park
1/4 mile: 10.88 @ 133.82 w/ 1.72 60'
Mods:
Engine: Diamond Pistons, Manley Rods, Cobra crank, 8.5:1 CR
Intake: Ported stock
TB: ported BBK twin 65mm[/b]
Power adder: Procharger D1 w/ 3.1 RR pulley @ 22#'s
Fuel system:Ford GT pumps, -8 line, 1/2 CPR fuel rails, Siemens 60lb. inj.
Drivetrain:Stock T-3650, Centerforce Dual Friction clutch, Fidanza aluminum flywheel, Steeda Tri-Ax shifter, aluminum driveshaft, Moser 31 spline axles, Eaton posi rear, 4.10 gears, welded torque boxes and axle tubes
Exhaust: Bassani mid-length headers & o/r x-pipe, Borla Stinger catback
Suspension: UPR k member, a-arms, coil overs(F), Eibach Sportline springs(R), Steeda U/LCA's, Steeda full length subframes
Sponsor: Myself
Here's a vid of the run: theblackmach1.flv - Video - Photobucket - Video and Image Hosting
Car now has an F1A and 3.73 gears and stock TB. No new times with this setup.
#8 · (Edited)
NAME : CHRIS KACZYNSKI / OU812MACH1
MAKE/MOD./YEAR : 2004 MACH-1 AUTOMATIC AT/4
TRACK NAME : MOROSO MOTORSPORTS PARK, WESTPALM BEACH FLORIDA
ET./ MPH :13.5 @103.19
MODS : S.C.T. CUSTOM PROGRAMMER{McDonald motorsports}, MAC/PACIFICA O/R X-PIPE, REMOVED AIR SILENCER, everything else factory stock
TIRE : GOODYEAR 245/45/17 FACTORY RUBBER @19PSI
SPONSOR : NONE
#9 ·
'03 Mach1 5spd, Oxford White, IUP
Track: Houston Raceway Park
1/4 mile: 11.31@120.71 /w 1.58 60' (on 26x10.5 ET Streets)
Mods:
JLT RAI
Mac 2.5" Pro-Chamber
FRPP Aluminum driveshaft
D&D SHD Cobra Clutch
Moser 31-Spline Axles
SCT PRP
NOS 5115/5116 Hybrid Dry Nitrous Kit (150 shot)
Sponsor: None
#11 ·
Nick H., Bonsall, CA
'03 Oxford White, 5 spd
Vortech @ 10 psi
no cooler
home ported intake
stock longblock
Bassani ML headers
Nitto 275 DRs
Eiback springs
Maximum LCAs
SCT PRP
everything else STOCK
full weight
granny shifted
11.97 @ 121 on only a 2.0 60 ft.
Great drag race combos you guys posted above. These are amazing cars.
#34 ·
Update:
I put on smaller injectors and MAF (60lbs to 39lbs, and SCT 2800 to Lightning 90mm), took off the Bassani headers, and put a Magnaflow cat-pipe on it. Passed emission test, took it to the track in that configuration and what the hell...it went quicker! Best was 11.83 @ 121. That was full weight and on tiny MT Streets. I forget the 60 foot but it was in the 1.9-2.0 range. The car is now super quiet and is a blast to drive on the street. It gets good mileage and is as mellow to putt as a Toyota sedan, LOL.
Nick, Bonsall, CA
Vortech @ 10 psi
no cooler
home ported intake
stock longblock
Bassani ML headers
Nitto 275 DRs
Eiback springs
Maximum LCAs
SCT PRP
full weight
granny shifted
#12 ·
Guillermo Esteves
Caguas, P.R.
Oxford White, 5spd
Track: Salinas Speedway, P.R.
1/4 mile : 12.81 @ 108 with a 1.89 60 ft (BFG drag radials 275/40-17)
Mods:
JLT & K/N intake
PHP intake spacer
Bassanni full exhaust
4.30 gear
SCT x2
FRPP aluminum driveshaft
Granny shifting
#30 ·
Mach 1 combos/times
The car improve with some modifictions to:
1/4 mile: 12.17 @ 110.77 with a 1.61 60ft
Lighter wheels in the front 17x4 alumastar and hoosier drag radials
In the back Bogart wheels 16x10 with ET street 26x11.5
off-road x pipe
weight reduction:passenger side seat,rear seat delete,spare tire,front stabilizer bar .
#13 ·
Make/Model/Year: 03 Mach
Track Name: MIR, MD
Time: 11.8@125.42
Modifications: 2.1 KB, UPR X-Pipe, Magna Flow Cat Back; SCT Tune, 4:10 gears.
#14 ·
Ryno
'03 AB 5spd w/IUP
Clay City, Ky
Time: 13.027 @ 109mph
1.9x 60ft
Mods:
PHP Intake spacer
K&N Filter only
Steeda timing adjuster +4 advance
2 1/2" Prochamber catless
2 1/2" Bassani mufflers welded in
245/45 Nitto DR's
that's it. car made 297/329 as above. NO TUNE
now has Dr Gas catless X, but doesnt feel any different,
just like the way it sounds. Awaiting 4.10's, Bassani ML's plus
matching X, cams, and ported heads..
#16 ·
Rjohn929
04 Mach 1 5sp
New England Dragway Epping, NH
13.078 @ 107.82
MODS
MGW shifter, SLP LMII, MAC longtubes, Catted H, Plasma Booster, C&L CAI MAF, Accufab throttle body, Denso plugs gapped to .052, Granatelli COP wires, MM ED lowers, Steeda adjustable uppers (pinion angle not correct), Nitto 555r (no traction)
Slow me Downs
Full stereo w/subs, full interior, stock rear end, 18x9 front wheels.
#19 ·
UPDATE to my time I ran a NEW BEST on the bottle!!!!!!
I finally ran in the 11's with the mods listed in my sig :dancing:!!!
break down of the run:
60'....................1.726
330...................4.890
1/8...................7.560
MPH..................91.59
1000.................9.881
1/4..................11.859:rockon:
MPH................114.06:good:
#22 · (Edited)
Name Norseman
Make/Model/Year 2003/Mach1/Black
Track Name Orlando Speed World
60' 2.068
1/8 7.8 @ 100
ET 11.6 @ 126mph
Mods See below
Sponsors My Paycheck
Max. HP 607
Max. Torque 654
Boost 9.75 psi Limited until I replace the stock drive train
DynoJet: VMP Tuning
These are not the best of times for my mods but, I am running a stock drivetrain including the clutch and am trying not to break things before I replace them. I have absolutely no traction and can't go full throttle until I hit third gear. After the first of the year I will be running some 26 X11.5 X 17 ET Streets. I originally started building the car for Track Events on a road race track but, ended up on the drag strip. That is why I'm doing things bass akwards.
#27 ·
Name Craig Svader
Make/Model/Year 2004 White Mach1
Track Name Atco raceway
Time 9.90
Modifications 314 stroker
stock heads
stock intake
stock cams
stock block
Oliver rods
Custom CP Pistons 8.5 to 1
Procharger F1A 19 pounds of boost
Weight 3650
Correction, weight now 3750 or more
engine size is now 281 with a cast iron block
short block is a MMR 900 with some upgrades.
heads are 04 cobra all stock now sporting GT cams
#25 ·
Greg
Bradenton Motorsposrts Park
Mods: 8# Procharger, LT's. and others
60' 1.816
1/8 7.685@94.75
1/4 11.810@123.88
Not bad IMHO for a stock bottomed Mach w/45k miles, OEM clutch, tranny, and a driver who has only been to the track three times. Like I tell others, fast car, slow driver. No weight savings other than the spare tire and jack removed.
#26 ·
Todd Frailey
2003 AB Mach1 5spd 1up/pkg
Carolina Dragway, Aiken, SC
1/8th = 7.488 @ 91.96
1/4 = 11.580 @ 119.45
60 ft = 1.64
Mods at the time of the run:
Stock bottom end
Polished D1SC ProCharger
4.10 (9#) pulley
3 core intercooler
FRPP 42# injectors
SCT BA2400 MAF
SCT XCal 2 Tuned by Rick at Amazon Tuning Solutions
03 Cobra tank and dual pumps
Spec stage 3 clutch
MGW orange handled shifter
03 Cobra aluminum driveshaft
stock rear, 3.55 gear, carrier & axles
17X9 Chrome AFS Wheels
275/40R17 MT ET Drag Radials
Autometer Phantom Tach
Autometer Phantom Vacuum/Boost Gauge
Autometer Phantom Electric Fuel Pressure Gauge
Autometer Phantom Intake Air Temperature Gauge
AEM UEGO Wideband
Mods since then:
Detroit Locker
FRPP 4.30 gears
Moser 31 Spline Axles
Weld Axle Tubes
Reinforced and welded battle boxes
UPR upper and lower control arms
#28 ·
Sponsored by myself.
Best 1/4 - 12.8 w/ a horrible 1.9 60 ft.
I know she has a 12.6 in her.
MODS:
Mac long tubes w/ O/R X and magna flow mufflers
Orange Blast ported intake w/ spacer
PSR k-member w/coil-overs
C&L cai w/ 85 mm MAF
4:10's
Prochrger in the works...
11's soon to come.
#29 ·
Cory
Track-MIR
11.72@124 1.81 60ft Nitto DR's
Motor-9.2 To 1 CR
Fuel-60lb Injectors,Focus Pump w/BAP,Mafia
Exhaust-Stock Manifolds with Bassani Cat-back and Xpipe
Power Adder-D1SC w/4.00 Pulley 11lbs w/Powerpipe
DriveTrain-Stock 3650 Trans w/26 Input Shaft and DFX Clutch,Stock Flywheel
Rearend-31 Spline Axles,4.10 gears,Cobra Diff,UPR Controls, Steeda Springs
Raceweight-3540 with Driver on Pump Gas 480/397 Mustang Dyno
