Mach 1 Combos/Times
Page 1 of 5 12345 Last
Results 1 to 15 of 72
    Senior Member Array Shoey's Avatar
    Nov 2003
    Las Vegas
    5,969
    Default Mach 1 Combos/Times
    Come on you Mach 1 guy's....post up your combos and times for other people to shoot for.
    I know some of you have some sick Mach's....let's see the #'s.
    You road race guys are welcome also, you guy's are over shadowed a lot buy the drag guy's. Here is a combo/times thread for you also.
    Format:
    Name
    Make/Model/Year
    Track Name
    Time
    Modifications
    Sponsors
    Nov 2003
    Las Vegas
    5,969
    Default Re: Mach 1 Combos/Times
    I will go through and make everyone's post into one "information" post every now and then to make the information easier to read.
    Thanks for making Modular Fords one of the best sites on the net!!
    Snake Bitten Moderator Array speedofsound's Avatar
    Oct 2004
    South Texas
    1,625
    everyone take time to list there mods. don't keep secrets.... not like the chebbie boys. here are all mine....
    Name: Robert Overfield
    Make/Model/Year: 2003 TR-Mach 1 5-speed
    Track Name: Guam International Raceway
    Time: 11.689 @ 118.131 w/ 1.667 60ft
    Modifications:
    C&L true flow CAI
    PHP spacer
    SpeedofSound Motorsports ported intake
    SpeedofSound Motorsports tuned
    longtubes w/3" collectors
    3" o/r true x
    magnapack cat-back
    NX kit w/ all the bells and whistles
    4.10
    hotchkis adj uppers
    hotchkis lowers
    D&D performance SHD clutch
    tri-ax
    Sponsors: SpeedofSound Motorsports
    all else is bone stock... even the race weight. right down to still installed jack and spare.
    waiting on my Crower stage 3's right now from Jared at Lethal. i got a Fastest Street car event that i'm sponsoring and running and raceing in at the end of April. hopefully all goes good with the cam install and my Mach rips.... gotta represent
  6. #4
    Senior Member Array Angus's Avatar
    Feb 2003
    AL
    885
    Make/Model/Year: Ford/Mach 1/2003
    Track Name: Cecil County Dragway
    Time: 11.354 @ 119.94 mph (Naturally-Aspirated)
    Modifications:
    Engine:
    Dyno Tune
    EGR Delete
    PHP Intake Spacer
    Electric water pump
    Custom-Made Cold Air Kit
    Ported Mach 1 lower intake
    Polyurethane Motor Mounts
    Driver-Adjustable Two-Step
    Alternator & p/s Underdrive Pullies
    NX 100 or 125-shot w/Safety Accessories
    Exhaust:
    SLP long-tubes
    SLP catless X-pipe
    Magnaflow Catback
    Weight reduction:
    A/C Delete
    No Passenger seat
    Lightweight Battery
    Lightweight driver seat
    Self-Made Rear Seat Delete
    Rear Mach 1 Sub Box removed
    No front sway bar, jack, spare tire
    Trunl Panels & Underhood liner removed
    Front & rear bumper support brackets + foam removed
    Stock radio/CD player replaced w/aftermarket gauges & panel
    Tires/Wheels:
    M/T ET Drag slicks
    Moroso DS-2 Front-Runners
    Centerline Warrior 15" Wheels
    (15" X 4" & 15" X 10")
    Transmission:
    Fidanza Aluminum Flywheel
    Mcleod Clutch & Pressure Plate
    Pro-Motion TKO Shifter (Steeda-Made)
    26-Spline TKO 500 Trans (Face-Plated)
    Adjustable Clutch Cable & Firewall Adjuster
    Suspension/Chassis:
    MM Full Length SFC's
    MM Caster/Camber Plates
    MM Adjustable anti-roll bar
    AJE Tubular K-member & A-Arms
    Welded Torque Boxes/Axle Tubes
    Front Coil-Overs with 175lb springs
    Adjustable Drag Struts & Drag Shocks
    Adjustable rear upper/lower control arms
    Rear:
    4.56 gears
    33-spline Moser Axles
    33-spline Moser Spool
    T/A Cover with bearing cap supports
    Misc:
    SLP Line Lock
    Manual Fan switch
    Programable/Recording Shift Light
    Sponsor: My checking account
    A video of my best N/A run can be found HERE.
  7. #5
    Senior Member Array INDY's Avatar
    Sep 2006
    between the shop and the track
    120
    Name-Shane Baker
    Make/Model/Year-Ford Mach 1 2003 Black Automatic
    Track Name- Speed World Phx AZ
    [email protected] W/2.0 60ft (before Billet T/C and built trans)
    Modifications
    Billet T/C 3500stall and built trans from BC Automotive
    Bass. cat back
    Mac o/r h-pipe
    K&N filter
    C&L tube only
    3.90 gears
    Nitto DR's
    Small shot on the bottle
    NGK TR6 plugs
    SCT switch chip (custom tuned by Devin @ Performance Solutions)
    UCA
    FSB removed
    Sponsor-Performance Solution
  8. #6
    Member Array B4THUNDER's Avatar
    Mar 2006
    Ocean Springs, MS
    35
    Matthew J. Holder "B4THUNDER"
    Ford/Mach1/'03
    No Problem Raceway, LA
    11.35 @ 125.65 mph
    Pro Turbo System Mach 1 Kit (10psi)
    Stock motor (@ the time of the run)
    Nitto DRs
    31 Spline Axles
    Sponsor: ProTurboSystems.net
  9. #7
    Senior Member Array TheBlkMach1's Avatar
    Apr 2005
    west palm beach, fl.
    275
    '03 Mach1 5spd.
    Track: Bradenton Motorsports Park
    1/4 mile: 10.88 @ 133.82 w/ 1.72 60'
    Mods:
    Engine: Diamond Pistons, Manley Rods, Cobra crank, 8.5:1 CR
    Intake: Ported stock
    TB: ported BBK twin 65mm[/b]
    Power adder: Procharger D1 w/ 3.1 RR pulley @ 22#'s
    Fuel system:Ford GT pumps, -8 line, 1/2 CPR fuel rails, Siemens 60lb. inj.
    Drivetrain:Stock T-3650, Centerforce Dual Friction clutch, Fidanza aluminum flywheel, Steeda Tri-Ax shifter, aluminum driveshaft, Moser 31 spline axles, Eaton posi rear, 4.10 gears, welded torque boxes and axle tubes
    Exhaust: Bassani mid-length headers & o/r x-pipe, Borla Stinger catback
    Suspension: UPR k member, a-arms, coil overs(F), Eibach Sportline springs(R), Steeda U/LCA's, Steeda full length subframes
    Sponsor: Myself
    Here's a vid of the run: theblackmach1.flv - Video - Photobucket - Video and Image Hosting
    Car now has an F1A and 3.73 gears and stock TB. No new times with this setup.
  10. #8
    NAME : CHRIS KACZYNSKI / OU812MACH1
    MAKE/MOD./YEAR : 2004 MACH-1 AUTOMATIC AT/4
    TRACK NAME : MOROSO MOTORSPORTS PARK, WESTPALM BEACH FLORIDA
    ET./ MPH :13.5 @103.19
    MODS : S.C.T. CUSTOM PROGRAMMER{McDonald motorsports}, MAC/PACIFICA O/R X-PIPE, REMOVED AIR SILENCER, everything else factory stock
    TIRE : GOODYEAR 245/45/17 FACTORY RUBBER @19PSI
    SPONSOR : NONE
  11. #9
    Senior Member Array LXH89's Avatar
    Dec 2002
    Houston, Tx
    374
    '03 Mach1 5spd, Oxford White, IUP
    Track: Houston Raceway Park
    1/4 mile: [email protected] /w 1.58 60' (on 26x10.5 ET Streets)
    Mods:
    JLT RAI
    Mac 2.5" Pro-Chamber
    FRPP Aluminum driveshaft
    D&D SHD Cobra Clutch
    Moser 31-Spline Axles
    SCT PRP
    NOS 5115/5116 Hybrid Dry Nitrous Kit (150 shot)
    Sponsor: None
  12. #10
    Senior Member Array ChuckP's Avatar
    Feb 2007
    Fayetteville, NC
    189
    Make/Model: White 04 Mach 1 5spd
    Track Name: Fayetteville Motorsports
    1/4 Mile: 13.090
    Mods:
    See signature below
    Still running on street tires, DR's coming soon.
  13. #11
    Nick H., Bonsall, CA
    '03 Oxford White, 5 spd
    Vortech @ 10 psi
    no cooler
    home ported intake
    stock longblock
    Bassani ML headers
    Nitto 275 DRs
    Eiback springs
    Maximum LCAs
    SCT PRP
    everything else STOCK
    full weight
    granny shifted
    11.97 @ 121 on only a 2.0 60 ft.
    Great drag race combos you guys posted above. These are amazing cars.
  14. #12
    Senior Member Array
    Feb 2006
    Puerto Rico
    241
    Guillermo Esteves
    Caguas, P.R.
    Oxford White, 5spd
    Track: Salinas Speedway, P.R.
    1/4 mile : 12.81 @ 108 with a 1.89 60 ft (BFG drag radials 275/40-17)
    Mods:
    JLT & K/N intake
    PHP intake spacer
    Bassanni full exhaust
    4.30 gear
    SCT x2
    FRPP aluminum driveshaft
    Granny shifting
  15. #13
    Senior Member Array robjr67's Avatar
    Aug 2006
    Stafford, VA
    258
    Make/Model/Year: 03 Mach
    Track Name: MIR, MD
    Time: [email protected]
    Modifications: 2.1 KB, UPR X-Pipe, Magna Flow Cat Back; SCT Tune, 4:10 gears.
  16. #14
    Ryno
    '03 AB 5spd w/IUP
    Clay City, Ky
    Time: 13.027 @ 109mph
    1.9x 60ft
    Mods:
    PHP Intake spacer
    K&N Filter only
    Steeda timing adjuster +4 advance
    2 1/2" Prochamber catless
    2 1/2" Bassani mufflers welded in
    245/45 Nitto DR's
    that's it. car made 297/329 as above. NO TUNE
    now has Dr Gas catless X, but doesnt feel any different,
    just like the way it sounds. Awaiting 4.10's, Bassani ML's plus
    matching X, cams, and ported heads..
  17. #15
    Sep 2006
    120
    Quote Originally Posted by INDY View Post
    Name-Shane Baker
    Modifications
    Bass. cat back
    Mac o/r h-pipe
    K&N filter
    C&L tube only
    3.90 gears
    Nitto DR's
    NGK TR6 plugs
    UCA
    FSB removed
    UPDATE:
    I ran a 12.304 @ 112 with a 1.85 60' time last weekend on a 100 shot!!!!!!!!!!!!! Heading back out this weekend to hunt down that 11sec slip. I left a lot on the table on that pass, I don't plan to leave anything on the table this wekend.
  18. Remove Advertisements
  1. H/C/I Combos... Who is running what?
    By Phil Jacques in forum 1996 - 2004 Mustang GT
    Last Post: 11-10-2010, 12:21 PM
  2. Nitrous Combos
    By Magic in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 12-30-2007, 01:03 PM
  3. exhaust combos?
    By da_boss in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 10-21-2005, 09:41 PM
  4. Cool Mach 1 T-Shirts & Hat combos
    By BgDaddy in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 04-20-2004, 02:46 PM
  5. Post your Mach 1 quarter mile times!
    By Turboniam in forum 1996 - 2004 Mustang GT
    Last Post: 12-10-2003, 07:04 AM
