1 - 2 of 2 Posts
Anyone know where I can find a 114" 8 rib belt.....The new idler pulley that vortech makes has a larger dia. requires a larger belt...any help would be appreciated...The belt I am currently running is 2870 mm in length having to run old Gt idler pulley to make it work.:confused:
Snake Charmer
Belt designations are pretty simple for example if you normally ran a pn 4060990 that would be a 6 rib belt (3rd number from left designation) and the length would be 99 inches. for an 8 rib same length as number above it would be 4080990, so if your looking for a 114" 8 rib try 4080114. Many places are lame and will only look belts up by vehicle make/model etc but if you find a nice shop that will look up PN's etc you should be set.
1 - 2 of 2 Posts
