1 - 15 of 15 Posts
Kinda goes by hp or how much boost , if you are making 430-460
the 9" is fine, 490 up the 12", I still have the 9" , I will install the 12" soon. I have them on order
nitro
Sitting still on a dyno probably not going to show much gains but going down the 1/4 mile i believe the 12"inch helps.I have seen a modded 03 cobra and a 00 lightning install 12"inch filters at the track and there mph went up over there 9"inch that they had on.I recently changed to a 12" inch filter and am very pleased on how the car performs with it on compared to the in the fender unit i was using.
ALLNTRL said:
FYI, S&B also makes a 10" filter, I got one sitting right here on the floor! :D The part # is R40-010PS if anyone wants one. ;)
Who carries these Filters? How good are they?Do they come with open end?
jim v.
When I was at the dyno and after the car was tuned to 463rwhp SAE I removed the 9" that comes w/ the Densecharger and ran it wide open and picked up at most 3-4rwhp so I'm not sure a 12" will get you much at that level w/ that CAI.. thats all I can say since thats all Ive tried, no track comparison which would be real helpful as well.. Jerry
jim v.
Jim, I special ordered it from a company called Bakerprecision out of Califorinia. But, this place had ABSOLUTELY the WORST customer service I have ever had from ANYONE!!!! I found them on the net one night as being a S&B dealer with the correct size filter to fit the '03 Cobra listed but in a 10". So I called them to see about getting one and Of course they didn't have one in stock, so I asked if they could order me one and they said sure no problem but it would take 2-3 weeks to get it to me I said ok go ahead and get me one and I would like it with a Black end cap they said ok. Well, my time goes by and still no filter, I call and they say should be here any time, well to make a long story short 2 MONTH'S later I finally get my filter open the box and it is the correct size but it has a chrome end cap! :mad: Anyway, now that I have a part # any S&B filter dealer (Amazon) should be able to order you one. This S&B is just like the 9" & 12" one's everybody else is selling except it's just 10" instead and YES it does have the opening on the end as well, that is what the PS in the part # stands for (powerstack). I don't know if you could use a 12" filter will your PHP air box, but I bet you could use a 10". ;) :D Hope that helps.
Thank's.. I'll find one...
jim v.
Jim, you can get the endcap in black instead of chrome(they're available either way) you just need to specifiy which you want. ;)
Jerry, the DC filter is a 6", not a 9". Or, you've somehow managed to do what none of us have, and got a 9" from John? :confused:
So what your saying is that you picked up 3 or 4 rhp with NO filter attached, compared to the 6"?
Some information I've seen has told me that a 6" filter is good for up to 600 crank hp, while others say 475rhp is the limit of what it can take, and that a 9" is a must at that point.
I'm one confused Toad at this point......
Would a 12" filter fit? Looks a little too tight.
Toad, sorry you're right, it IS the 6" that I have w/ the DC. And yes when I removed the 6" filter off the DC and ran it NO filter it picked up 3-4 hp near the top end. Some of that 3-4 hp could have been run-run variance, the other was probably a slight gain.
Jerry
What does everyone use the open end of the filter for?? Is it so U can pull the headlight at the track ??? I am thinking of a big open ended filter for my car as well, but would like some sort of ram air like the JLP , anyone care to elaborate??
1 - 15 of 15 Posts
