Tuned with the 3.4
Page 1 of 5 12345 Last
Results 1 to 15 of 73
    Senior Member Array Shaggy's Avatar
    Nov 2005
    St. Charles, IL
    333
    Default Tuned with the 3.4
    Just got the cobra tuned with the 3.4. It made 19psi as opposed to the 22psi I was told the pulley combo would make. Either way It feels pretty damn good.
    Wheels spun alittle bit on the dyno.
    I dont feel 19psi is enough for this thing to realy shine. Im trying to figure out why it made less. My guess is that the Mteco 6.5" lower is reducing boost more than the advertised 2lbs.
    Senior Member Array
    Jul 2007
    Ogden, UT
    188
    Default Re: Tuned with the 3.4
    stock engine? (bore and c/r at least?)
    Oct 2002
    Eastpoint, FL
    19,253
    I'm not being negative, just honest, but those numbers are low for 19 psi. Any idea how much timing was seen on the datalog?
  6. #4
    Nov 2005
    St. Charles, IL
    333
    Quote Originally Posted by Got Trq View Post
    bone stock, so im not loosing boost through anything like that. stock manifolds too.
    that run had 21* I think this blower realy needs to be up to atleast 21psi
  7. #5
    Senior Member Array stangfreak's Avatar
    Jul 2003
    long island, new york
    6,191
    run it at the track and see how it does. The numbers for a big blower like that at 19psi or whatever pulley combo that is, are kinda low. but then again, dyno numbers are just that.
    I am still a believer in the 2.2 and 2.3 blowers for our 4.6's
  8. #6
    Senior Member Array
    Jul 2007
    Ogden, UT
    188
    2.2's are getting harder to find now :(
  9. #7
    Senior Member Array mr. couper's Avatar
    Mar 2006
    San Antonio, TX
    764
    what pulley combo gave you 19?
  10. #8
    Nov 2005
    St. Charles, IL
    333
    Quote Originally Posted by stangfreak View Post
    exactly
    Im not big on making huge numbers on the dyno, the car ****ing rips like a bat out of hell and thats what I want.
    I am gonna run it up to 22lbs once I figure out why its less than it should be.
  11. #9
    Nov 2005
    St. Charles, IL
    333
    Quote Originally Posted by mr. couper View Post
    3.50" upper and the Metco 6.5" lower.
    Ive posted this in a few threads on a few sites. I believe the lower is reducing boost more than 2lbs as Metco advertised. The smaller lower could also be a factor in my lack of torque.
  12. #10
    Senior Member Array
    Jul 2007
    Ogden, UT
    188
    Put some manifolds on that beast I'm sure it will help, maybe those GT cams and ported heads.
  13. #11
    Nov 2005
    St. Charles, IL
    333
    My car is far from done if it thought otherwise. Its not getting off this easy!
  14. #12
    Mar 2006
    San Antonio, TX
    764
    so a 4 inch upper would give you 17psi. what other lower do you have to put on to see how much you boost goes up.
  15. #13
    Senior Member Array
    Jul 2007
    Ogden, UT
    188
    Quote Originally Posted by Shaggy View Post
    haha I like the way you think
    I have major plans for my car when I get back from this upcoming deployment.
  16. #14
    Nov 2005
    St. Charles, IL
    333
    I dont. I had the stock lower before. If the lower is the culprit then a 4.00" upper would be 16psi.
  17. #15
    Nov 2005
    St. Charles, IL
    333
    Were all crazy, some more than others!
    Are you millitary or just travel for work?
  18. Remove Advertisements
  1. E85 tuned!!
    By jbt930 in forum E85, Ethanol, Methanol and other Alcohol Alternate Fuels
    Last Post: 10-23-2010, 02:19 PM
  2. tuned
    By mikeys01 in forum 1996 - 2004 Mustang GT
    Last Post: 05-28-2007, 04:06 PM
  3. Just had my car tuned
    By 00sentra00 in forum 1996 - 2004 Mustang GT
    Last Post: 04-10-2007, 01:33 PM
  4. Where to get a car tuned in IL
    By WhiteWhippled04 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-31-2006, 11:57 AM
