Ysi
Results 1 to 6 of 6
Thread: Ysi
    Default Ysi
    I will be getting the CCW YSI for My 02 mustang GT 5-speed with a stroker built 2V. I will use the 8 rib pulley kit. What blower pulley size do I need to run 24-26lbs of boost? 2.80? It will be primarily a track car using 110+ octane.
    Paxton / Vortech Superchargers Array
    Aug 2007
    591
    Default Re: Ysi
    I"ll have to get more info to be able to answer your question. PM me your email address and I'll send you a performance estimate sheet.
    Default Re: Ysi
    the YSI is rated for 60,000 rmp with a amax of 65,000, if you run a 7.5 crank pulley with a 2.80 blower pulley would bring it to about 55,500 rpm @ 6000 rpm if you shift @ 6500 rpm would bring the unit up to 60,000 which would be in the 25-28 psi range depending on heads cam an other factors.
    the formula your looking for is
    Crank pulley size X 3.45X rpm divided by blower pulley size.
    good luck
    oh ya HANG ON!!!!!
  6. #4
    Default Re: Ysi
    Quote Originally Posted by hotford View Post
    good luck
    oh ya HANG ON!!!!!
    Wow! Thanks for the info. This is exactly what I was looking for!
  7. #5
    Senior Member Array Hysteria's Avatar
    Aug 2006
    Tampa, Fl
    916
    Default Re: Ysi
    good luck
    oh ya HANG ON!!!!!
    Chris where did you get that fomula, Mike Regan?
    Good info!
    What pulley are you going to start off with using the JT Trim???
  8. #6
    Default Re: Ysi
    Quote Originally Posted by CJBlackmon View Post
    Good info!
    Well I do talk to mike from time to time but all this info is on there web site , as for my J-T trim gonna be a 7.5 crank 8 rib set up with a 3.15 blower pulley shifting @ 7500 rpm.
  9. Remove Advertisements
