21 - 40 of 45 Posts
· Administrator
Those cams are used and also use 10mm fastener hardware.
If you are intent on using the 03/04 Cobra cams, I have a brand new set, never run, that have been drilled and tapped for 1/2 x 13, 8740 ARP 12-point bolts that I'll sell for the same $300 price. ARP specs the torque on a 10mm 8740 fastener as 62 ft/lbs. The ARP spec on the 1/2 inch 8740 bolt is 125 ft/lbs. Ford specs the torque on their 10mm TTY single-use fasteners at 30 ft/lbs plus 90˚ of additional rptation. The ARP fasteners are reusable the FRPP fasteners are not. The cams will need both the ARP bolts and four ARP washers that are 0.275" thick. Both the 12 point bolts and washers are standard off-the-shelf ARP items available through Summit.
ARP offers the identical thickness and diameter washer for 7/16" and 1/2" bolts. The 7/16" is $9.99 each and the 1/2" is $11.99 each. If you have drilling facilities, you can save a little on the washers by using the 7/16" washer. The 7/16" washer part # is ARP 200-8717 and the 1/2" washer part # is ARP 200-8749. The Summit pic for the 1/2" washer is wrong. The part # is not. The 12 point bolt part number is ARP 627-1750. I would recommend the 7/16" washer drilled out for the 1/2" hardware.
Before you drill the washer you will notice one side has a chamfer as delivered from ARP. The chamfer is there to avoid the radius on the underside of the 12 point bolt head. If you just drill the washer without duplicating the clearance chamfer you will eventually snap the head off the bolt. The head normally leaves the bolt at a relatively high engine speed bending lots of valves, breaking guides and sometimes dropping valves that punch holes in heads and cylinder walls — and I haven't even gotten to what it does to the pistons. Be sure to re-chanfer the washers.
Let me know what you would like to do.
67 Fairlane 500XL. Planning on a 32 valve 4.6, 4r70w swap
Discussion Starter · #23 ·
Those cams are both used and also use 10mm fastener hardware. If you are intent on using the 03/04 Cobra cams, I have a brand new set, never run, that have been drilled and tapped for 1/2 x 13, 8740 ARP 12-point bolts that I'll sell for the same $300 price. ARP specs the torque on a 10mm 8740 fastener as 62 ft/lbs. The ARP spec on the 1/2 inch 8740 bolt is 125 ft/lbs. Ford specs the torque on their 10mm TTY single-use fasteners at 30 ft/lbs plus 90˚ of additional rptation. The ARP fasteners are reusable the FRPP fasteners are not. The cams will need both the ARP bolts and four ARP washers that are 0.275" thick. Both the 12 point bolts and washers are standard off-the-shelf ARP items available through Summit. Let me know what you would like to do.
Thanks for the offer... I thought the 03-04 cobra cams were the same as the stock Lincoln cams.... This posting is for 96-98, which , I thought, were a little hotter. Am I mistaken?
· Administrator
In the 03/04 SVT Cobra Forum, check in the TToC under the Engine heading, and you will find a posting named Cam and Valve Timing Spreadsheet by yours truly. When you open it up, you will find almost all the Ford Modmotor cams, their nomenclature, their specs, and their part numbers. There are also a number of aftermarket cams listed. The Ford part numbers change a whisker across the years, but you should be able to identify the cams easily from the data there. NA/SVT was good enough to share some Cam Doctor specs he had personally collected for several of the cams listed. Where he did, I have noted it.
Discussion Starter · #27 ·
I was able to confirm the part numbers and bought them... Thanks again. I'm sure I'll have more questions in the near future.
Discussion Starter · #29 ·
New book arrived yesterday. Already about halfway through reading it... Answers a lot of questions and concerns I had. Confirmed for me I can fit the Teksid into the Fairlane with only notching the shock towers. I'd recommend it to anyone considering this kind of swap.
Getting tired of not being able to work on my own projects and might go ahead and pull the Lincoln into the shop this weekend and start pulling the motor...
Discussion Starter · #33 ·
Cobra cams showed up today in the mail. Haven't even opened the package yet... Working on leveling a new storage unit next to the shop so I can move some stuff over to make more room for the big old 4v motor tear down.
If you can get a forged crank grab it but I'm not sure where you can even get one these days at a reasonable price..
ks
  • Like
Reactions: mercenvy_3114
Discussion Starter · #40 ·
ks
Found a used one for $800. New ones for $1,000 and up. Also read about using a 5.0 crank and getting it machined to fit, but I don't think any of the local machine shops I would trust to do that work.
21 - 40 of 45 Posts
