1997 Mustang Cobra Convertible with 83,000 miles on body
Crystal White with Tan Top and Tan Leather Interior
#903 of a build of 3088, built 3/11/1997
(copy of VIN identified SVT customer letter and certificate included)
Ford Factory Cobra replacement motor with 13,000 miles
(Previous owner didn't pay attention to oil temp at VIR - spun bearing at 70k - replacement engine has ford tag 1/14/05)
Fully loaded - Mach 460 stereo, power everything, leather, etc.
Full interior intact - Everything works, even the A/C.
Modifications:
Entire maximum motorsports "max grip package" ($5k in parts) to include:
Maximum Motorsports Strut Tower Brace
Maximum Motorsports Tubular front K-Member
Maximum Motorsports Tubular K-Member Brace
Maximum Motorsports Tubular Front Control Arms w/ urethane bushings
Maximum Motorsports Front Coil-Over Conversion Kit (450lbs)
Maximum Motorsports Adjustable Tie-Rod Ends
Maximum Motorsports Standard Torque-arm
Maximum Motorsports Full Length Subframe Connectors
Maximum Motorsports Aluminum rack bushings
Maximum Motorsports Rear Panhard Bar with Aluminum rod
Maximum Motorsports Adjustable Rear Swaybar
Maximum Motorsports Fully Adjustable Caster/Camber Plates
Maximum Motorsports Tubular Rear Lower Control Arms without spring perch
Maximum Motorsports Rear Coil-Over Conversion Kit (450lbs)
Additionional Mods:
Kenny Brown fully welded extreme tubular Matrix chassis brace
Kenny Brown jacking rails
AutoPower 4-point race roll bar w/ harness bar.
Hypercoil springs
Bilstein HD Race valved struts
Urethane swaybar bushings
Urethane swaybar endlinks
Solid steering shaft
Delrin bushings
Ford Racing Performance Parts 3.73 rear gears
Spec Stage 2 clutch (done at 70k with engine replacement)
Pro 5.0 Shifter with MGW adjustable shift handle
Off-Road H-pipe and MIL eliminators
(I also have a set of brand new high flow cats to weld in if needed)
Canton Road Race oil pan (Mobil 1 Changed frequently)
Maximum Motorsports oil filter relocation kit with t-fitting for oil accumulator
(no accumulator installed yet)
WMS Cold air intake
Brembo Gran Turismo 2000 Cobra R 4-piston aluminum front brake calipers
Cadmium-plated slotted brake rotors, 13" front, 11.65" rear
(not sure of pads installed currently - but plenty of life)
DOT Stainless steel brake lines
Kenny Brown Front brake ducts with spindle mounted backing plates
(misplaced spindle mounted plates, but still have ducts)
Firestone SZ50EP 275/40R17 tires
17x9 Chrome Mustang Oem 2003 Cobra rims
Black Konig Touring seats
Simpson 5-point harnesses
Ford Racing Performance Parts black FR500 steering wheel (airbags intact)
Ratings & full disclosure:
Mechanically & Suspension: 9.5/10: Very Firm ride, some noise from coil overs during low speed very high amplitude turns, ie parking - MM says there may be a flange in the strut tower that was not hammered down per directions so it maybe making contact - haven't had time to look at. I would just suggest a nut and bolt for safety/tech inspection and your off to a track day near you : )
Exterior: 8/10: not perfect - minor bugs/stone chips/& tire kick up from light track use and being original 97 paint - but cleans up nicer then most original paint cars that haven't been on a track. The only major paint blem that bothers me is a scrape from a garage door handle falling on the center of rear bumper. There are also two holes drilled inside the fog light recesses inorder to mount brake ducts - and if you were on the ground looking up at the front bumper some scrapes underneath from road contact. (I have the foglights for those who want them & wiring is still there)
Interior: 8.5/10: Overall very very nice. Only issue is Driver side
race seat side bulster has worn tear from enter/exiting, I have original nice shape saddle leather seats to include if you want to slide all over the dam place. Volume button on radio shows some wear.
Conclusions:
Car is currently set up as a very well balanced, well sorted road racer / high performance driving event car / track day / summer weekend fun car. Simply put, It handles amazing - the power is so use-able (be it straight line or in the twisties), that it is consistently faster than several heavily modified high HP stangs I've owned. It's also been very reliable for me -finding a car that you can drive to an event, finish it competitively, and then driven home with all the luxuries for under 10k isn't easy to find, - the only hard choice is top down or A/C on. I have a clear title in my hands.
My only reason for selling is due to job change: I'm going to have less time/weekends to commit to doing track events/auto cross, and would rather just have a fun new s197 to more comfortably street drive daily to work in the summer instead of my truck. The cobra suspension/race seats just aren't up for commuting 1hr into the city - and frankly it wouldn't be fair to this great car. This cobra would make an excellent platform to build a project from - the power is so plant-able - I can't imagine it with a blower or turbo - it would be nuts. If not, with just a quick going over & detail it up a bit for the season, it's ready to go with no issues. Car is currently garaged in upstate NY. Let me know if anyone is interested. It's a great car I'd be willing to letting go at a great price! PM me
$9,250 OBO
Pictures:
Yfrog - 38rhcylheadfrt.jpg - Uploaded by FirstR
Yfrog - niceautlr
Yfrog - bremboh - Uploaded by FirstR
Yfrog - cobrapictures004 - Uploaded by FirstR
Yfrog - cobra1w - Uploaded by FirstR
Yfrog - rear2u - Uploaded by FirstR
Yfrog - cobrapictures027 - Uploaded by FirstR
Yfrog - interiors - Uploaded by FirstR
Yfrog - cageo - Uploaded by FirstR
Note: when looking at the underside picture, all MM parts on my stang are actually powder coated black except kb chassis brace, blue was done in photoshop to highlight modifications. Also, changes from the picture: I have less aggressive sway bar on rear, open h pipe, and finished exhaust from axle to stock cobra tips. -Matt
