Hydroboost diagram?
Page 1 of 2 12 Last
Results 1 to 15 of 20
    Senior Member Array 32Vcoupe's Avatar
    Dec 2007
    cincinnati, OH
    310
    Default Hydroboost diagram?
    Anybody have a diagram of how these hoses route? I have 3 new hoses all high pressure, from the length and fittings I'm pretty sure I know where they go. But what about the low pressure (i assume I have to cut and hose clamp?) line on the hydro boost unit. I dont know if that goes to the resivior or where. Also the return from the rack, through the cooler then back to the resivior or ? I looked under the hood of a '03 cobra, but it was rainy and dark couldnt see much. A diagram of the hose routing would help out greatly. Thanks in advance. Joe
    Senior Member Array
    Mar 2006
    New Brunswick Canada
    315
    Default Re: Hydroboost diagram?
    This should help,its an 04 mach but same,same
    Dec 2007
    cincinnati, OH
    310
    Thanks so much,helps a ton!
  6. #4
    Senior Member Array 66dvlbrd68's Avatar
    Aug 2007
    Albuquerque, New Mexico
    177
    Damn, I haven't gotten into my mod swap, but I'm sure this info will come in handy at a later date.
    Awesome.
  7. #5
    Senior Member Array
    Mar 2006
    315
    Anything else like that,just pm me.
  8. #6
    Do you know where to find the fitting size and type? I pulled the lower metal hose off of my PS pump and it had a nipple flare on the end, which my flare kti will never do. lol. Maybe a billet piece?
  9. #7
    yeah thanks for the diagram
    anybody used the booster just for the brakes? and how do you pipe that up?
    I dont need the power steering but would like to make use of the pump
    already with my engine to give me power brakes . . . not sure how the pipes should go?
    anyhoo . . jack
  10. #8
    Senior Member Array
    Mar 2006
    315
    I would think you could take the hose to and from the rack and join them??You might need a restrictor in it???
  11. #9
    Quote Originally Posted by dil View Post
    can u please ID the lines and which one goes where? it is kinda hard to c from the diagram where each one goes? thank u
  12. #10
    Senior Member Array
    Mar 2006
    315
    Let me know what ones you are having an issue with?
    Big hose fitting on top of HB is the feed from the PS pump.
    Big hose fitting on the lower/side/back of the HB goes to the steering rack inlet (bottom fitting on rack).
    Small hose fitting on the lower/side/front of the HB goes to the PS reservoir return.
    Newer HB units don't use that 3-tree junction next to the fender. The lines run directly to their destinations.
  13. #11
    I like this one:
  14. #12
    Thanks much for the diagrams and pics! Im having to modify and trim for fitment into my 66 Coupe.... this helps bigtime!
    KT.
  15. #13
    No problem, man. Anytime.
  16. #14
    has anyone switch to AN fittings and braided lines for the power steering??? and relocating the power steering resevior. im having fitment issues & leaks with my custom turbo kit
  17. #15
    ^^^ This is what I plan to do. Need to get the motor back in before I plumb it though.
    I know there are some pics @ this site, as well as fittings to do the swap:
    http://www.hydratechbraking.com/Hydr...ultimedia.html
    http://www.hydratechbraking.com/prod...cessories.html
  18. Remove Advertisements
Page 1 of 2 12 Last
  1. Need hydroboost help...
    By wicked93gs in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 08-22-2010, 06:58 PM
  2. Need help with hydroboost.
    By 96saleen206 in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 07-12-2010, 07:45 PM
  3. need help with hydroboost!
    By runsonboost in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-31-2009, 01:44 AM
  4. hydroboost..all the same
    By SloSVO in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 07-20-2009, 09:51 AM
  5. Hydroboost ?'s
    By ASCapri in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 08-16-2007, 04:00 PM
