1 - 13 of 13 Posts
help me guys i cant figure when to shift, some guys say 5300 some say 6000 i go at 6000 and get low 14's sometimes high 13's with my mods i should be low 13's best et is [email protected] with a 2.3 60ft (crapy i know) when i shift at 5300 i break loose big time 1-2,2-3,3-4 when i shift at 6000 i get a little chirp and nothing 3-4
Discussion Starter · #2 ·
thats with no nos, i only have a n/a problem
If you ever had it on a dyno, the shop would be able to tell you from the graph what a good shift point would be for your setup. If not, I would try and get to one if your that concerned with it.
I think everyone here can say I shift at this or that, and it may not be right for him. Unless you can see on a dyno chart where the powerbands are, you will never know what your best shift point is unless you do nothing but change it till you find the right spot.
between 5800 and 6K. Lighten up your car. remove swaybars, quad shocks, spare tire/jack, rear seats and dogbone. No washer fluid and race with 1/8 tank of gas
im getting a dyno done on the 9th i already set up the appointment but im just curious for around the town races. im just shooting for a 13.3 in full street trim
I cant say this enough. BE CAREFULL doing that on the streets. More people get killed that way, usually innocent bystanders. Tis why 98% of the people here do their racing on the track.
Are you going to Sac tonight? If so come on by. I'll be in the 01 Grey GT With Draglites all the way around.
what is up with that 60/ft? damn dude i think that you have 2 work on that first or get some nittos or somthing.look i did 102 mph and look at what a 1.7 60ft did for me.My car made peak power at 5200rpm and i shift about 5700rpm's.shifting at this rpm has netted me the best times and mph at the track.ph yeah nad learn how 2 drive:cool:
Discussion Starter · #11 ·
im not going to the track for a while
but do you roll with sacstangs or know jens or tarik?
Discussion Starter · #13 ·
tuffpny
1 - 13 of 13 Posts
