I posted this not long ago, but figured it needed a new thread, since it has some new power numbers.
A friend of mine is toying around with the idea of selling his built 99 GT. Car is silver with dark grey cloth interior. Car has all working factory options, and at times is used as a daily driver with no problems, idles and drives pretty much like a stocker until the loud pedal goes down.
The run down on it is
Motor:
5.4 Swap w/ Manley Pistons, Manley H Beam Rods, Forged Navigator Crankshaft, Cobra Oil Pump, ARP Main, Head and Oil Pan Studs, ARP Side Cap Studs, 9.2:1 Compression
Navigator 4v Heads Ported by Modular Head Shop w/ Comp .500 Lift Springs @ 130 LBS of Seat Pressure, and 98 Cobra Cams
MMR Sheet Metal Upper Box Intake w/ Navigator Lower
75mm Throttle Body
Meziere Electric Water Pump
Turbo System:
Custom built turbo kit using a
Borg Warner SX80 Turbo with a 1.07 A/R & T6 Dual Scroll Flange, & Custom Race Impeller
Treadstone 4.5x33x17 Intercooler (low IAT's with this!)
Procharger Race BOV
Turbonetics 45mm Race Gate
Oil Relocation Kit
HPX Slot Style Maf & Diablo MAFIA
3.5" Cold Side Piping
Now has 2.5" Exhaust ran all the way to a set of tips (no mufflers)
Kit clears ac, power steering, automatic transmission, everything.
Drivetrain:
Lentech Strip Terminator 4R70W Transmission w/ Manual Valve Body & Lentech 2400ish Stall Converter, Autometer Transmission Temp Gauge
B&M Transmission Cooler & Stainless Lines
B&M Hammer Shifter
Moser 28 Spline Axles
3.27 Gears
FMS Aluminum Driveshaft
AJE Tubular K Member w/ Urethane Mounts (and an extra set of solid mounts)
BBK Subframe Connectors
17x9 & 17x10.5 Deep Dish Bullitts (clear is peeling on rears)
315 Mickey Thompson Drag Radials (just added in the last month)
Fuel System:
Complete Return Style Conversion utilizing the following
Aeromotive Eliminator Pump (rated to 1400 HP)
12AN Stainless Feed Line to Pump
10AN Stainless Line to Y Block at the Rails
Aeromotive Billet Fuel Rails
Aeromotive Race Fuel Pressure Regulator
Ford Racing 80LB Injectors
15 Gallon Fuel Cell in Trunk (uses stock fuel level gauge & low warning light)
Car also has stock tank still in it, if you want to convert back to that
Misc:
Kaenen 4.5" Cobra R Hood (need to clear 5.4 motor)
Stock Spoiler Moved Back 2"
Battery Relocated to Trunk
Two Pusher Fans & 1 Puller Fan (needed to clear turbo & maintain ac condenser)
SCT Xcal2 Programmer
Tuned by XXX Motorsports:
649 rwhp through the unlocked converter, SAE on a Dynojet on STRAIGHT PUMP GAS, NO METHANOL, on only 15 degrees of timing, on 19 psi (previously made 647 rwhp on 18 psi before adding the MT Drag Radials, and exhaust).
804 RWHP & 725 RWTQ on race gas at 26 psi as of the other day, through the exhaust.
This transmission shows alot less on the dyno than a stick would, the 03 Cobra that it was previously in showed 100-120 RWHP LESS than what it did with the T56, so you can imagine how much power this car is really making at the flywheel.
Car has full interior, ice cold ac, working heat, power windows, power locks, power steering, cruise control, power driver seat, power mirrors, keyless, Mach 460 Stereo. Paint is good for the most part, has some small scratches on a fender, and the interior is in good shape.
Has approx 84k miles on body. Motor & turbo kit only have a couple thousand miles on them, motor has excellent compression, no knocking or smoking. Transmission setup has around 4000 miles on it.
The bad is, car needs a new cowl panel & windshield, as the windshield has a crack from a rock flying up on the highway, the cowl panel was just worn out like most of them are, so he pulled it off for now. Car still has stock suspension because of his Wife wanting it to ride stock (she drove the car quite a bit over the years as well). Car has a few scratches and stuff here and there, but nothing crazy.
Car ran a [email protected] with a 1.68 60 ft in the 1/8, highest mph was 109.73, thats on PUMP GAS, 17's, and barely leaving with any boost. It has not been back on the track since doing the race gas tune.
He has had the car since 03, and has put alot of money into it, and just wants to sell it to invest more into his new business. He is looking for around $15k, could easily be a low 9 second car with some suspension work.
Serious inquires only. Car is located in NW Florida area.
Here is the 18 PUMP GAS dyno video from over a month ago, pics coming soon, but this video will give you an idea. Car currently has projector style head lights (I know lol) instead of the faded yellow ones in the video.
Are there any decent pics of the car to include the interior?
S.
S.
I need to get some, he doesnt have a camera. He opened a new repair shop, so he has been busy with that during the week.
I'm really interested in this car. Is there any contact info or additional pictures? I'm in central Florida and can probably make arrangements to see it in the next week or two.
S.
I will PM you his number. He needs to get pics of it, but is slammed during the week with the shop he opened. Im sure we can get it done though.
New cash price is $10000!
New price is $10000 CASH
or
POSSIBLE TRADE for a decent modded black/white/calypso/reef blue lx hatch or notch, or black 91-93 GT or black/white 94-95 Cobra (no automatics, no red interior, no verts, no carb cars, must have ac and heat) and at LEAST $5000 or MORE. Otherwise, it's $10000 CASH, this is the best deal you will find on a car with a built motor, turbo, built auto, fuel system, making this kind of power! Trade may also be considered straight up for a 99 up black/white/nassau blue/electron blue/grey C5 Corvette with a 6 Speed, or an 03 Cobra.
Pics and cold start/idle video, and race gas dyno can be seen in the ad here
http://forums.corral.net/forums/showthread.php?t=1261802
