Any problems with the ABS system with 26 in. front tires and 28 in. rear?
J JD's04 · Registered Joined May 6, 2004 · 72 Posts Discussion Starter · #1 · Nov 15, 2011 Only show this user Any problems with the ABS system with 26 in. front tires and 28 in. rear?
Bad Intention · Registered Joined Feb 24, 2010 · 997 Posts #2 · Nov 15, 2011 Only show this user I run Hoosier Pro Street radial on front 26" and MT 295/55/15 28" on rear for past 5000 miles no problem with ABS @ all.
O Omcar · Registered Joined Aug 5, 2010 · 764 Posts #3 · Nov 15, 2011 Only show this user I had that set-up....No problem
J JD's04 · Registered Joined May 6, 2004 · 72 Posts Discussion Starter · #4 · Nov 15, 2011 Only show this user Thanks for the info.
JohnnyZ · Registered Joined Feb 24, 2005 · 1,846 Posts #5 · Nov 17, 2011 Only show this user I was running that same setup before I swapped over to the 27" fronts and I had no issues.
D dwhuff · Registered Joined Aug 4, 2004 · 402 Posts #6 · Nov 18, 2011 Only show this user I have no issues with that same combo.
wnt2gofst · Registered Joined Oct 12, 2010 · 2,099 Posts #7 · Nov 18, 2011 Only show this user No issues here. I was surprised didn't though. But oh well.
J Jim Vaccaro · The Ubiquitous Jimmy V. Joined Oct 25, 2002 · 3,319 Posts #8 · Nov 22, 2011 Only show this user JohnnyZ said: I was running that same setup before I swapped over to the 27" fronts and I had no issues. Click to expand... Was that just a tire change or wheel change??
