1 - 15 of 15 Posts
Snake Charmer
Did I hear correctly that the 03 has an Air Charge Temp sensor before and after blower? If so, has anyone found these parameters in the autoap software?
Snake Charmer
IWRBB said:
Yes and yes.
hehe, well for tghe life of me I could find them in my autotap parameters (latest version 2.04) can you point me in the right direction? What are they called in autotap? Im curious to see what the temp difference is between the KB at 9psi and 17psi.
They may be listed as IAT1 and IAT2, which is the correct abbreviation for those sensors. (Intake Air Temperature Sensor)
Snake Charmer
IAT1 I see but cant seem to find IAT2
I think the second one is an "extended parameter". My Helion won't bring it up.
On autotap's page, for the palm at least, not sure about the other platforms, the software that does the extended parameter's is extra $.
JT
Snake Charmer
Im pretty sure I bought the one with extended paramaters.....but maybe not. WIll have to double check.
Snake Charmer
Yep, I got extended parameters. Here is a link which lists the parameters, am I blind and just missing it?
http://autotap.com/enhanced_parameters_ford.asp
Intake air temperature at the time of misfire
Intake Air Temperature Voltage or Air Charge Temperature
Would it be the last one in the list I quoted above?
Snake Charmer
When looking through the parameters on autotop I dont remember seeing "Intake Air Temperature Voltage or Air Charge Temperature" as it is listed on the website, I think it just says "Intake Air Temperature Voltage" which may explaine why I couldnt find it. Maybe you can select to display it in voltage or temp? I will check later when I have it in front of me.
I see there is a parameter called "COAST CLUTCH SOL-FAULT".
I guess that explains the stall when you COAST with the CLUTCH in...you're SOL for any damage caused as you smash your way through three lanes of traffic, its all your FAULT loser!
Snake Charmer
Discussion Starter · #12 ·
hehe, good one. On a side note, since installing my KB idle has been absolutely rock solid. never drops below 700rpm or so even on very long coasts.
:lol :lol :lol
There are two parameters...
"Intake Air Tempature" and
"Second Air Charge Temperature Sensor Input"
Make sure that your VIN number was entered correctly. I believe it checks the VIN to load the parameters
hope this helps...
Snake Charmer
Discussion Starter · #15 ·
Yep, that was it top racer, there are two identicle parms, the first didnt report didly but the second seemed to work fine.
1 - 15 of 15 Posts
