1 - 20 of 28 Posts
No Limit is now offering dyno proven solid adjustable lifters.
18.00 each. They are direct replacements and require no cylinder head modifications. We have seen as much as 35HP due to controlled lift and timing accuracy.
Well.....you will probably sell a million of them. I already know a couple of guys. Could we see some pictures ??
Thanks Dale
sweet... looks like a good product.
*digs round to find 288 bucks*
That IS a very neat looking piece.....just one more question. How do you keep the adjuster body from spinning in the cylinder head when you tighten the jam nut?
Thanks Dale
Thanks Dale
You tighten it against the allen tool
I like the simple design. These are gonna be great for those guys out there with regrinds.
Any guess how often the lash will need to be adjusted on a street car?
David
Good ? Dave!!!!!
Will you see rwhp improvement without changing from the stock cam??And are these for 2vs
stupid question: whats the web site? i will order a set in a month or so.
The 2V and 4V motors both use the same hydraulic adjusters and rocker arms so these solid adjusters will fit both motors.
Dale
1 - 20 of 28 Posts
