Radiator
1 - 13 of 13 Posts
These are proven to do almost nothing for you unless you are a hardcore road racer. I'd save your money or spend it else where.
For an eaton car I agree with G03SVT about just keeping the stock rad.
I am starting to see now with my 3.4L whipple that I need a bigger rad and some cooling upgrades. Driving down the highway as I go a bit faster my temps increase, I have to slow down to decrease them and even then they sit at 205-210 in the summer which is much hotter then I would like and Canada isn't warm by a lot of your standards(AZ, New Mexico, Texas, Florida)
Just know and do some research as a rad alone won't drop your temps significantly.
I upgraded to a 03-04 cobra radiator. :rofl:
Just stick with what you have.
I am thinking about doing what Jameshell did and remove all the restrictions in the system first and run a stock rad(I think James is using a stock rad)
It will run a bit more expensive then an upgraded rad, but maybe it will be enough to drop my temps?
Steeda/C+R. It was only $100 used, so I figured why not..
LFP Radiator has been one for about 4 months and haven't had a problem.
LFP.
Got it way back in 05 when it was on special for $279.00
Hasn't leaked or blown up yet so I guess it's OK.
The only thing I have noticed about it is it doesn't hold a shine. I have to keep re-polishing it.
I think next time I will Zoop Seal it after I polish it.
New LIVER mod ROCKS!
A thicker rad core REQUIRES more air pressure differential in order to provide any increase in heat rejection. A thicker rad with the same amount of air supplied to it will actually flow less air though it.
If you run a road race style heavily vented hood then even a stock radiator will cool much better.
A stock hood and a big radiator just takes longer to over heat.
My LFP leaked after 4years, if this epoxy doesn't seal it I going to get a Fluidyne.
(Open track/ road racer type right here)
I have an LFP in my coupe
and a eBay one($160) in my 04 Cobra
they look similar and both work the same
My FLUIDYNE failed at the welds...I would not recommend that garbage to anyone. Good luck.
4.6 ways to waste money
LFP here. Bought them way back when and no problems to date with the Rad or H/E. It can't hurt right?
1 - 13 of 13 Posts
