1 - 7 of 7 Posts
I rarely use the air,but the other day I tried it and didn't work.I checked the fuses.Checked the system pressure.Added 1 can of 134.It appeared ok.But it was still blowing warm air.I really hate to remove a few mods to take it back to the dealer.Any ideas of the problem would be appreciated ?.I dont need the cobra to be hot it 2 ways.thanks STEVE THOMAS:
Night Trains Daddy
not blowing or not getting cold?
Could be a vacuum leak
Its just blowing warm air
I have the same exact problem. I also do not want to go to the dealership to have them look because of all the wrok i have done to my car. I will have to bring it to a loacl place and see if they can find anything wrong.
matt
If a can of 134 fixed it, you probably have a leak somewhere. Most factory a/c systems have a low pressure switch that will keep the compressor off if there is not sufficient refrigerant pressure.
If you are sure you don't have a leak, I would check the fuses.
JT
Not trying to suggest the obvious, but. Did you check the compressor clutch to make sure that it is engaging. I just had the same problem on my other Ford ( explorer). The compressor was not turning because the push on connector to the electric clutch had fallen off. Pushed it back and had instant cold air.
The compressor clutch will kick on for a very short period of time.thanks for the suggestions. still trying
1 - 7 of 7 Posts
