Try getting in touch with Justin at JPC Racing, I found him to be very knowledgeable about where things break, he told me he even broke 3 Boss 50 big bore blocks.
GT throttle body or GT500 throttle body?Ok....here it is. Aluminator shortblock 9:1 compression 3V, frpp intake, frpp shorty headers, comp cams xfi-spr stage 2 cams with springs and retainers, livernoise phaser lockouts, turbonetics 05-09and turbo kit with hurricane series banita 78mm compressor/ 68mm turbine, stock throttle body cause the BBK broke, frpp one step colder plugs. Now I took it to a mustang specific shop nothing but stangs in the shop period. So they should know what they are doing. However even with all of that under the hood I only ended up with 550hp/550tq rwhp!?!?!?!?!?!?!?!?! WTF!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!? I should have at least be seeing 650+ horse and torque. Unless I completely missed something. Please someone enlighten me or just explain how stupid I am...
Are you running 127-450 cams? I have those in my car but use the phaser limiters instead of the lockouts. You just max your cam timing to 18*-20* and should be good to go.Tuner said he thinks it could be the livernoise lockouts considering the last couple 3v's they locked out lost 80-100rwhp. Crappy thing though "IF" I have them unlock the cam phasers I might as well have them double check the mechanical cam timing as well while they are digging into it. Just in case the shop that installed them screwed up. I mean yeah they can build 1000-1500rwhp supras but I've yet to see another american car in their shop since I took it to them a year ago. (The shop that installed the cams that is)
