With the engine up and running - again - I've had some time over the last couple weeks to do some reading on the intercoolers and figured it would be worth sharing some more info. Even though the factory Garrett intercooler has worked fine all these years, with their dwindling supply, the "upgraded" Griffin version did fascinate me enough to keep researching them (and I've taken some flak over that by people who say there is no way the OE version can be beat). The new one is in, and the coolant is flowing nicely by the way, but I can't really comment on the IAT's yet since the car won't leave the garage for a couple more months. In any case, the downstream temps while at idle have been sitting about 30° warmer than the upstream (i.e., 70° inlet and 100° outlet), which may or may not be significant.
Moving on, I happened to get my hands on a leaky OE intercooler and decided to have some fun with it by "taking it apart". I'd imagine the insides of them have never been seen (not that they are overly complicated), but wanted to share some of the findings before I update this thread again with some tips and tricks that went along with the Whipple installation - not that those are too difficult either. I also added this stuff to the
Cooling page on my site.
So, here is the donor. In this picture, much of the
sealant along the top had rotted away, so I pulled the rest off which somewhat shows the gaps around the flange:
The mounting plate is just a stamping that is set on top, with some welds on the sides to secure it before the sealant is added. There are probably plenty that leak once the original sealant comes apart, but that can be fixed easily enough (which can still be an inconvenience). The top plate removed once I cut all the welds:
The intercooler body as it sits "naked":
Once that was done, I sawed the rear end cap off to show a cross-section of the core (along with the crud that I didn't bother to clean out). The coolant flows in through the lower half of the body, then pools in the end cap and is then pumped up and towards the front where it exits to the tank. Here you can see the upper and lower half with some details I added (again, looking at it from the rear):
That same view next to the end cap, also showing the coolant flow direction (If your pump croaks, the coolant is definitely just going to sit there and get toasty). I probably mentioned already that these have 9 rows, but this one happens to be mucked up on the outsides with the welds, so it may have limited some of the flow back to the tank, making it kind of a 7-1/2 row version...
The front and rear end caps side-by-side. The inlet is a bit restricted as you can see, thanks to the divider plate and probably partially due to the way the inlet tubes fit on the intake manifold (showing again, the coolant flow, minus the actual intercooler body obviously):
With all that in mind, I wasn't about to buy another Griffin intercooler to cut up and see what has improved, but I have my thoughts. It may have to do with the size of the halves, at the very least, since it appears the lower (cooler side) is larger than the upper (hot side). There's also the additional row of fins, plus the better design. With no sealant on the top, it isn't going to leak there, so that is nice as well. Maybe I can get some info right from Griffin or LFP, but those are my insights so far. Here's a side-by-side again from the front of both (the frontal dimensions are about 4 x 3" for the Garrett and 3-1/2 x 3-1/2" for the Griffin):
Anyway, after doing some reading comparing the fin design, I have seen arguments that the OE bar-and-plate is more efficient, but most say the extruded tubes are better since they allow more coolant flow and heat transfer, which I would tend to agree with. Here's a generic comparison of the two, with the OE-style on the right:
From the charge side, the air is potentially going to flow smoother with the extruded-tube fins since they are all rounded, whereas the bar-and-plate multi-piece design is flat. I found this picture on the internet illustrating that:
Something else I found that is interesting is that Whipple is making their kits for the S550 Mustang with their own intercooler that is also shorter, which is exactly the way this version sits. Theoretically, the incoming air can make a smoother turn at the bottom, which was probably a consideration with the new Griffin version being shorter as well. Not sure how much of an advantage that really offers, but they must have felt it was also worthwhile. An image of one of their kits illustrating some finer points:
Otherwise, I'm looking forward to hitting the road again one of these days once the weather gets nicer, and will keep this thread updated, especially since I'll get to the dyno again soon as well. Will also add some more pictures with the Whipple install in the near future.
