Well I put the car away for the winter but I will check on that before I put it back on the road. Thank you.The door switch is activated by the plastic roller on the bottom hinge. My roller broke apart and is no longer around the hinge. After awhile, the plastic roller gets dented in over time. I pulled the cartridge lamp out of the dome light, until I can think of a brilliant fix for it, without removing the entire door.
