1 - 2 of 2 Posts
How much lift would I be able to use w/ a 0cc flat top, .020 under deck (romeo block, so I've been told)?
Anybody usin' that kinda piston? If so how much valve lift and duration are you runnin'? (you don't have to divulge your cam spec's if you don't want to a workable range would be sufficient :cool: )
Any info is appreciated, thanks.
SJ
good question. I opted to use 5cc instead of flattops with the Modmax 25102 cams with 535/575 lifts. I had no idea, so better safe than sorry. I do know that some are now using the Comp race cams with flat tops and no issues, but those lifts are a little less around the 550 range.
1 - 2 of 2 Posts
