We took the 5.0 to Dallas Raceway yesterday, it was a nice day but a lot of wind. I will only run this car how I drive it on the street, so all passes were made with full weight, and on 18" wheels all the way around. The same wheels and tires I drive it daily with. This car still has the stock 3.15 gears, stock converter, stock 6spd auto, stock motor, stockish fuel system, etc.. This car daily drives like a dream! It is very quiet, smooth, & gets good gas mileage. I truly enjoy driving it, even though I normally drive like a grandma. It usually won't see over 1,800rpm on a 20 mile drive to work. At 45mph in 6 gear it is like 1,100rpm, pretty much idles along barely touching the gas.
I originally planned on twins. I felt like I needed a tubular K member to build the way we planned. After a long wait, I had a conversation with Kenne Bell and shortly after I had a polished 3.6l liquid cooled blower on the car. Since this was the route, I decided to put American Racing Headers and H-pipe. The car already had a Magnaflow 3" street series catback.
So first pass down the 1/4 mile it spun a little and went [email protected], then it hooked good and went [email protected] and kind of short shifted 4th. So I adjusted the shift points a little and gave it a little more power out of the hole. It then went the best 60' which was 1.49 but bumped the limiter on a couple shifts so it went [email protected] again. At this point I was frustrated and ready to go, but the guys talked me into one more pass. So I dropped the shift points where it hit the limiter and it did perfect. It left hard did a 1.50 60', ran a [email protected] in the 1/8 and a [email protected] in the 1/4. I am super impressed with this car. Driving next to it or in it you would never know that much is done to it. When you floor it, all hell breaks loose.
BTW it made 760rwhp and 660rwtq thru the stock auto on 15psi with E-85 which is all I ever run.
