1 - 5 of 5 Posts
Snake Charmer
The rims on these cars are heavy, I was wondering if anyone knows what they weigh? Preferably weight of the chromies.
I just weighed the stock rims/tires this weekend because I swapped out to new rims/tires.
Stock non-chrome rims/tires = 53lbs
for a comparison (what I switched to):
(Front) Chrome AFS 18x9 + 275/35/18 Kuhmo Ecsta MX tires = 55lbs
(Rear) Chrome AFS 18x10.5 + 295/35/18 Kuhmo Ecsta MX tires = 61lbs
Ok,,So that Combo adds 20lbs...I thought it would be more..
Thank's good info!!
Snake Charmer
Thank's good info!!
Probably even less than 20lbs if you have stock crhome rims. I like the look of the 18's better but you end up moving weight out farther away from the hub and hence increase rotational mass, wonder how it will affect performance?
Not sure what it will do to my times at the track and I won't be able to do a direct comparison either because I also swapped a 2.93 pulley for a 2.8 pulley at the same time (a friend demodded his Cobra to sell it so I got a few of his goodies).
On the street though it seems to grip a bit better and has helped reduce the wheel spin that I used to get all the time at the top of first. Considering I can feel a bit more torque from the pulley/chip swap I think the rims were a good choice.
1 - 5 of 5 Posts
