Found this: http://www.jandssafeguard.com
Looks like an interesting product. Basically a complete active knock sensor system which allows you to run optimal timing at boost. Basically eliminating the need to pull out a set amount of timing per PSI of boost, instead it pulls out just enough timing per cylinder when it senses the slight onset of detonation for that cylinder allowing you to run optimal timing at any boost level/rpm.
Just wanted to find out if anyone had any experience with this product, good or bad. Thanks!
