1 - 15 of 15 Posts
I've heard those shread the belts pretty badly.
I bet it helps slippage though...I had a friend with a Novi I think that did something like that to the ribs and it helped his slippage. Not sure if it destroyed his belts......
Night Trains Daddy
I guess I'll find out. :D
I have an idler coming also...needless to say I don't plan on losing any races because of belt slip. :p
GOOD POINT:lol
I too, heard that it will decrease the life of your belt. If it does, its no big loss though, belts and pulleys aren't that expensive. But I hope it works good for you. Let us know how they do, good luck.
The BarTender
I have the Reichard pulley. It's actually a 3.12 diameter wich I later found was too small for my combo. I had to switch back to a 3.6 to lower the boost. Anyway they do eliminate slipping along with "Increasing" belt life. That's right it increases it. How do I know? Well to be honest I don't, but the word is that renegade class racers use these pulleys to eliminate slip. They found a nice side effect being that the belts also lasted allot longer as well. You can view the Reichard pulley on my website (Link in Sig) I have put it in the for sale section since I can't use it. BTW Reichard charges $200 for that pulley.;)
Razor.
Razor.
It might be increasing the belt life since it is preventing slip wear. Two positives so what is the negative?
The BarTender
Too much $$$$$$$$:eek:
Razor.
Night Trains Daddy
Discussion Starter · #14 ·
Reichard is a rip-off call S-E Racing there only $80 :D
The BarTender
Dam that's a good price!!!:D I guess I should make mine a christmas ornament.
Razor.
1 - 15 of 15 Posts
