Alright i think that this is my problem. I have a 2000 gt with bullitt intake, with the PA converson harness for the alternator. Everything has worked fine for a long time. Now i am getting the dreaded P0300 MULTIPLE MISFIRE. After checking everything out I am getting 29-30 volts AC from the alternator its charging fine but its getting a constant missfire under load. Anybody got any thoughts on this. How much AC voltage does a bad diode let thru. I tested my new work van and it puts out .5 volts or below so i know what its supposed to be. Does a bad one put out 29-30 volts like I'm reading.
