One bad 2v
Those of you that swapped in a built auto, what did you get? Where did you get it? Where did you get a shifter and what are you using? Links would be great and any info on the swap would also be great. I would like to use a built 4r70w for ease of install but if there is something better for the same price that would be great.
I got a jw th400 built for over 1k hp from MPH.
B & M ratchet shifter
A th400 is going to be a lot stronger than a 4r70 so you need to decide if you want a 3 spd or not.
