My saga continues with my second attempt to get this unit tuned. As most of you remember, last time I have a tensioner go out on my engine as well as the SPEC 4 clutch letting go at 3500rpms. I now have the Mcleod twin disk clutch and aluminum flywheel in with roughly 350 breaking miles so far. I hope to put another 50 miles or so on before dynoing. Other changes that Have been made are the addition of a 40hp Nitrous system and modyfied stock intake. This intake is very similar to the intake that picked up Bob Cosby's N/A Cobra 33hp over 5K rpms. I think this intake should really benefit my blown application!!
To people that don't know what my setup is I will give a quick rundown so that you can get an idea of what I am doing.
Car is a 96 Cobra with D&D tubular K-member and coil overs, 90/10 Lakewoods, Hal adjustable rears, HPM Megabite Jr LCA's, Lakewood uppers, UPR battle boxes, UPR anti-roll bar, 6-pt roll bar, Detroit locker with 4.56 gears, 31-spline axles, aluminum driveshaft, TKO tranny, scattershield, Mcleoud clutch and flywheel, Weldon Fuel system, built 99 DOHC with Manley rods, 8.5:1 CP pistons, SHM girdle, SHM oil pump gears, ModMax trigger wheel, Ported heads with Ferra valves, ModMax springs, Titanium locks and retainers. 55lb injecters w/FMU, Vortech JT trim ~23psi, stock 99 Cobra cams and a host of other things to make it all work.
Original setup was basically a built shortblock 96 engine with 18psi S-trim that ran [email protected] I am shooting for high 9's with this setup with no nitrous.
Chris Johnson of JMS will be doing all the tuning on his new Mustang Dyno. I will report back with the results as soon as it hits the dyno. I just hope all goes well this time!!
Good Luck Focker!!!! You better call my monkey ass when you put it on the rollers!!!! LMAO
Jeff
Best of luck to you.. Being fairly new here, I am totally amazed at all the Hi-HP cars on this board.. Kinda makes me feel outta place..lol.. But I guess if you want to be fast, you don't need to be educated by slower people..;)
The BarTender
Good luck Chad! I can't wait to hear how it goes man.:D
Razor.
Good luck Chad. I was going to get my car tuned by Chris Johnson Today(4-3-03) but my MSD ignition died last Sunday so I had to call and cancel. Maybe I can make it in a week or two. I was hoping to see how much H/P 20 or more pounds of boost from my JT trim would make? I guess you will get to see first. :D Thanks, Jeff B.(1BAD98)
A friend of mine just had the same problem with his Cobra.. he ended up getting new MSD and calling JMS to get a 4-way program burned for it.
Should be ready to go this weekend... it is a yellow 98 w/ 16#'s of boost and a 100 shot, on a forged engine.
Best of luck to you also.:D
My DIS 4 also died and was replaced with a new unit by MSD, they also checked my tach adapters and said they were fine.
