Just thinking ahead guys just in case. What Bellhousing is required to run a G-Force and/or Jerrico tranny. I guess a better question is what all is necessary to run such a tranny? Right now I have a TKO 5-speed, Mcleod Sof-Lok clutch, Lakewood bell housing and Aluminum Motorsport driveshaft. thanks
Chad, I am relatively certain that the bellhousing you are currently using will work, same with the driveshaft.. You are just going to have to specify which yoke you will need.
Ben
Thanks Ben, I really had no idea. I figured they required their own special bell. If not, then this is great news. Maybe Mike will chime in on his setup. I wander what tranny he is using?
Jerico
Chad,
I have a Jerico DR4. I'm using a typical Lakewood bell. I have a custom driveshaft. The output yoke is from a TH-400. Either one of those trannies will require you to do some tunnel "re-modeling" to clear the shifter linkage. If you decide you want to put one in, let me know. I am still looking to find an auto that will hold up to the abuse of 11,000 rpm shifts! :evil :evil :evil :evil
