1 - 8 of 8 Posts
Hi Everyone. Hoping for some help with a belt issue. On my car I'm using the TurnKey bracket setup to run the A/C and powersteering. In order to keep the belt off of the upper radiator hose/Intake-to-thermostat-housing-hose we have the belt pulled toward the passenger side. Revving the engine up threw the belt and bent the bracket we had made (you can see where it was cut and welded. I have the bracket at a machine shop to see if they can make it out of a piece of billet. In the mean time I believe if I could run -AN lines to the intake and move the thermostat housing then I could route the belt differently and eliminate the issue. FRPP sells a 10 Rib kit that I can't use as is but may be a start. Also, in this picture http://www.summitracing.com/parts/fms-m-8511-m5010 it shows modified housing parts. Does anyone know where to get these? Any other ideas? Thanks!
1 - 8 of 8 Posts
