1 - 7 of 7 Posts
The Canadian Snowbra
Hey guys, if you look into the piston wells (if that's what they're called) you'll see these black caps, that make it so you can't really see the nitty girtty peices of the brakes. Does anyone know what these are called, and where I can get them?
Here's a pictures of calipers WITHOUT them.
http://img123.imageshack.us/img123/6197/img3284bj5.jpg
Thanks guys, if you have no idea what parts I'm talking about, I can try and explain it better, but in those 'wells' you'll see there is no black circular cover at the bottom, and I think it makes my calipers look terrible.
The "black caps" as you are referring to them, is part of the outside brake pad.
The pad pushes into the holes in the caliper, and that's what holds it in place. If you look around the edge of the hole you'll see the triagular looking points that grab ahold of the sides of the hole. If yours look bad it's probably because they've been out in the elements a lot and they've faded.
Easiest way to fix this is to take the caliper off and hang it in the fenderwell with a piece of clothes hanger... pull the pad out and paint inside the holes in the pad. It's either that or get new pads to fix the "cosmetic" problem.
Shannon
i have the 10th anniv calipers on my GT and the plugs you mention are actually attached to the pads. They center the pad in the caliper and help to hold it in place. I have stock cobra pads that came with the calipers
And it all becomes clear, that's the type of answer I was waiting for. I'm not a moron, and I've taken apart a bunch of calipers. I honestly thought that perhaps there was a black insert that you slid into those wells, which rested on the back of the pad (or heat shield if there is one). I just have yet to take apart the calipers and pads on my Cobra.
Thanks for the info!
1 - 7 of 7 Posts
