1 - 7 of 7 Posts
uh-hmm you will see more than 25psi at 7500 with a 3.12. Ben Dorn has that pulley setup on his car with a T-trim and sees 26psi with it below 7500. I'd say the 3.33!
Chad
Are you sure Ben has that setup?Ya know,he has been accused of saying things are bigger than they really are..:) Hell he probably has a 2.60 pulley on his.
Thanks,I guess I'll try the 3.33 first.
How is your ride doing?
Tim
I use a 3.15" pulley on my JT. But I am only using the stock crank pulley. I get 17psi @ 7500 and 20psi @ 8000. I also run an 8-rib and dont have any visible signs of major belt slip.
I am curious how much boost increase the overdrive crank pulley gives.
Dave
Yes it should, hehe, I just happened to know he has a JT- trim Vortech!:D
Chad
1 - 7 of 7 Posts
